Hi looking at options for boost hoses. I need 2 inch bore and capable of 10 psi so it doesn’t have to be heavy duty.
Would something like this be suitable
https://www.ebay.co....tm/184632052163
It says good to 260 degrees C and resists collapse.
Don’t want to spend the earth on silicone and tonnes of bends also would like some to flexible if possible. Open to suggestions
Boost Hoses Advice
dyshipfakta
, May 11 2021 06:43 PM
5 replies to this topic
Posted 11 May 2021 - 06:43 PM
Posted 11 May 2021 - 07:20 PM
I wouldn't use that for boost hose, it'll tear under pressure.
Why not check ebay to see if anyone is selling used couplers and pipe?
Posted 11 May 2021 - 09:28 PM
There’s no way I’d use that under boost. The silicone bends aren’t expensive and will be completely reliable.
Phil.
Phil.
Posted 11 May 2021 - 11:00 PM
So silicone and alloy pipe work is the only really way to go. Was hoping that for 8 psi would get away with something more flexible and be able to run slight curves to get it to where it needs to go.
Posted 13 May 2021 - 04:55 PM
You just have to spend the money. I spent a lot of time measuring (ruler and angle-finder) to minimise the hoses I used, not because of cost but for neatness and packaging.
Even with that I still spent best part of £200 on hoses. But buying a decent brand (Samco for the most part), it’s a onetime cost.
https://www.autosiliconehoses.com is a good, lower cost alternative to Samco.
Posted 13 May 2021 - 07:26 PM
Fair shout I am too after neatness. I had hoped that at 2 inch bore there might be some alternatives but if not I will just have to bite the bullet.
Andy
Andy
