Braided Clutch Hose
10 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 11 May 2021 - 07:18 PM
wanted to put in a braided clutch hose between the master cylinder and the slave cylinder on my clutch. A because it looks nice, B because I like the practicality of a banjo set up and finally I like a bit of bling, who doesn't?
Bought the banjos and bolts from Mini sport for the Mini, 3/8, (9.525mm). When I looked at Mini clutch braided hoses....OMG.......these really are expensive, despite being nice and shiney.
Whilst browsing, I came across some braided lines for Motorcycles, banjo fittings 10mm, with the added bonus that they were available at many lengths ranging from 50mm up to 2 Meters and they were incredibly good value ranging from £10 to £20, compared to the car ones which ranged from £40 upward.
Decided to go for it, HOWEVER   they don't fit? for some reason even tho the mini banjo bolt is 3/8 fitting the final part of the shaft, where the largest copper ring goes onto is about 11mm and so won't fit. We all like a bargain but sometimes it all goes wrong. :(
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 May 2021 - 07:22 PM
This is the one Ive fitted https://www.minispar...px|Back to shop
#3 Steve220
Steve220
  • 5,084 posts
  • Local Club: BMC
Posted 11 May 2021 - 07:24 PM
https://store.classi...-conversion-kit
£26 with stainless fasteners.
#4 nicklouse
  • 18,751 posts
Posted 11 May 2021 - 07:26 PM
As above. All the parts you need for £20ish
#5 Miki Leyland
Miki Leyland
  • 125 posts
Posted 11 May 2021 - 11:26 PM
Excuse me but what are the advantages of these braided lines instead of the solid original ones? Do these last longer?
#6 nicklouse
  • 18,751 posts
Posted 11 May 2021 - 11:54 PM
Allows you to shift the slave out of the way when doing the clutch or engine out.  Same as putting them on the MC/servo  gives space.
they can last longer.
#7 Bobbins
Bobbins
  • 1,525 posts
Posted 12 May 2021 - 06:20 AM
A stainless braid protects the internal rubber hose ... which is effectively the same as the non-braided version. Be wary of anywhere that the stainless braid contacts, it will rub through paint and solid copper line in a remarkably quick time, easily protected though with a rubber cover at the contact point. Ironic really.
#8 GraemeC
GraemeC
  • 7,451 posts
Posted 12 May 2021 - 07:03 AM
Not in (decent quality) brake and clutch hoses. A braided hose will have a PTFE inner which will not brake down the same as rubber and therefore not become a ‘one way valve’ that is a common problem with older OE style brake and clutch hoses.
#9 Bobbins
Bobbins
  • 1,525 posts
Posted 12 May 2021 - 09:01 AM
Yes, good point Graeme.
#10 Ethel
  • 26,156 posts
Posted 12 May 2021 - 09:39 AM
PTFE will crease &  crack though, so you need to take a bit more care to avoid twisting & bending them to tightly.
#11 splintercat
splintercat
  • 616 posts
Posted 13 May 2021 - 05:15 PM
nice one, just contacted a hydraulic hose making company at Silverstone, I live in Northampton, they will make me any length, any color, braided.....for £24.
