Poor spark
Posted 05 November 2006 - 12:16 PM
Engine is 1330cc, stage 3 head, fast road cam, aldon fast road distributor with magnetronic electronic ignition module and ballast resistor. I have wired the black wire from the module to the negative side of the coil and the red wire to just before the ballast resistor.
Does this make any sense:-
Resistance across coil 4 Ohms
Voltage across coil 5 Volts
Voltage across coil, starter cranking 2.5 Volts
Voltage across coil, engine running 3.8 Volts
All i can think is that there is some sort of wiring problem that i need to look for because those measurements look a bit pants.
Posted 05 November 2006 - 12:23 PM
if its taking a long time to start my engine used to do this try starting without the choke when it fire then pull the choke out or put your foot on the pedal to lift the revs worked a treat on mine
Posted 05 November 2006 - 01:09 PM
I've tried loads of combinations of choke to no avail, all i could think was the poor spark isn't enough to start it when it's been left overnight.
Posted 05 November 2006 - 01:13 PM
Posted 05 November 2006 - 03:48 PM
On my old 1098 I put a small bead of silicone round the base of the dizzy wear the cap seats, let it set and then when you put the cap on it createsa seal, it worked great, never got condesation and didn't break the seal down for about a year!
Dry electrics are happy electrics, electrics doused in WD40 are bodged electrics.
Degrease the cap inards with white spirit, then I made sure it was all dry inside the dizzy with a light hairdrying lol, lightly oil moving parts with 3-1 and then replace cap.
Posted 05 November 2006 - 05:00 PM
Posted 05 November 2006 - 08:59 PM
dave
Posted 06 November 2006 - 07:53 AM
Posted 06 November 2006 - 12:26 PM
No, Don't spray WD40 under the cap, it does seem to help a bit but For the cap to function correctly it needs to be Dry! not wet!
as retro 10's don't spray it inside the cap it can cause problems i should have said on the outside
last month when it was really peeing it down the car started to misfire the dizzy was that wet it was arching on the outside of the cap put a pastic bag on it after 10 mins she was alright but she didn't want to start in the morning sparyed some wd40 and it started almost straight away
have you had the car rolling roaded still sounds like my problem with the choke might be over fueling at low revs
ps what plugs, leads etc are you using
Edited by theoldtartspimp, 06 November 2006 - 12:28 PM.
Posted 06 November 2006 - 12:41 PM
Posted 06 November 2006 - 01:16 PM
"Engine is 1330cc, stage 3 head, fast road cam, aldon fast road distributor with magnetronic electronic ignition module and ballast resistor. I have wired the black wire from the module to the negative side of the coil and the red wire to just before the ballast resistor"
Repeat your voltage measurement tests if they were not performed as follows.
1) At the coil, mark and disconnect the low tension wires.
2) Use ohm-meter across the bare low tension terminals on the coil.
3) With the low tension wires still disconnected (and loose ends not touching anything) measure across the ballast resistor.
Attempting resistance measurements with wire connected to a circuit will introduce errors as other elements are adding to the equation.
On the other hand, to measure voltage drops you want all the normal wiring connected. In this case, with the low tension wires hooked to the coil, place your meter in volts mode across the low tension terminals. For voltage drop measurements you must have current flowing. To insure this, temporarily connect a jumper wire from coil (-) to chassis ground and switch on the ignition. Your meter will now show the voltage drop across the coil. You can't get an accurate measurement of this voltage with the engine running.... the current is turning on and off each time a cylinder fires. With the jumper wire in place you're forcing a continuous current flow and you should measure a voltage drop across the coil close to 6V.
My first take on your numbers above is that you might have the ballast resistor connected incorrectly. In addition to the ballast resistor connection on coil (+), there should also be a wire going off to an extra terminal on the starter solenoid. The intent here is that you "bypass" the ballast resistor so the coil gets more power/voltage while you're cranking the engine. Your 2.5V value seems WAY too low.
Posted 06 November 2006 - 08:08 PM
I carried out the checks before as you said, as well as the additional one; so to re-itterate, we have:-
Resistance across coil, terminals disconnected 4.4 Ohms
Resistance across ballast resistor, terminals disconnected 4 Ohms
Voltage across coil, terminals connected 5.3 Volts
Voltage across coil, jumper wire between coil-and ground 5.8 Volts
I agree that the 2.5 Volts whilst cranking sounds well pants, any ideas? Maybe it's a case of bad wiring somewhere?
Posted 06 November 2006 - 09:40 PM
Now I admit I've never worked on Magnetronic... so they could be unique installations... but I've never seen a coil or a ballast resistor that measure close to 4 ohms. As I think I mentioned earlier, a typical ballast resistor will be close to 1.5 ohms and the ballast coil to go with it will also be somewhere between 1 to 2 ohms.
Your measurement of the coil voltage with the jumper in place sounds about right since you're measuring 4 ohms on the ballast and 4.4 ohms on the coil. Doing the math based on your numbers, your battery may only be at 11 volts. (I won't bore you with the details here). A battery in good order will typically show around 12.5 to 13 volts with no loads attached. Be sure to check your battery voltage before going too much further.
You didn't mention if you have the wire between the solenoid and the Coil (+) terminal.
Posted 07 November 2006 - 02:52 PM
Posted 07 November 2006 - 05:35 PM
Proper readings are as follows:-
Resistance across coil, terminals disconnected 1.6 Ohms
Resistance across ballast resistor, terminals disconnected 1.2 Ohms
If any light could be shed now it would be a great help, would love to get this sorted!
