Hi
Any body knows what diameter has the rear brake disc from kad development??
thanks
Best Answer nicklouse , 15 May 2021 - 07:36 PM
5th Jun, 2009 at 07:40:07pm
For reference,
The KAD rear disks are 7.5 inches in diameter, 4mm wide and are bolted in a cross pattern approximately 93mm apart.
Cheers,
David
Go to the full post
Posted 15 May 2021 - 03:24 PM
Hi
thanks
Posted 15 May 2021 - 03:49 PM
I am guessing here but 7.75” as that is the size they give for there calipers that fit under 10” wheels and these as well.
so 7.5-7.75”
Posted 15 May 2021 - 07:11 PM
I would’ve said much smaller, nearer 6”
Looking at the photo here, given the PCD of the stud holes is 4”
https://kentautodeve...onversion-discs
I guess if they were too big they’d give too much rear braking.
Posted 15 May 2021 - 07:36 PM Best Answer
For reference,
Cheers,
David
Posted 15 May 2021 - 08:18 PM
Ah - they’re not the stud holes are they, forgot they were on a carrier
Posted 16 May 2021 - 12:27 AM
Thanks a lot!
