Lucas Fuse Box Replacement
Posted 22 May 2021 - 10:44 AM
I am replacing my 32yr old Lucas fuse box today. I Have bought a genuine Lucas replacement however there is a difference:
Terminals 1 and 3 of the new item are permanently connected by a short bus-bar on the underside.
If I'm correct, this means that lots of electrics will remain powered up even with ignition off since terminal 3 (brown) goes straight to battery.
So have I ordered the wrong unit? Or should I cut the bus bar out?
Or I could install it upside down?
Any advice much appreciated.
Rich.
Posted 22 May 2021 - 11:10 AM
Posted 22 May 2021 - 11:29 AM
Posted 22 May 2021 - 11:43 AM
Posted 22 May 2021 - 11:56 AM
Posted 22 May 2021 - 11:15 PM
Posted 23 May 2021 - 09:20 AM
The standard fuse box doesn’t have the bus bar, but I think the fuse box with the bus bar was used on an MG, possibly the B?
All minis I have are the 4 fuse box, all have the bus bar fitted
Posted 23 May 2021 - 09:45 AM
Should not have.
Posted 23 May 2021 - 05:36 PM
I don't dispute what you're saying and thanks for chipping in but surely if you follow the standard connections 1-8 you must have stop lights , indicators and heated rear screen all available with ignition off?
All minis I have are the 4 fuse box, all have the bus bar fittedThe standard fuse box doesn’t have the bus bar, but I think the fuse box with the bus bar was used on an MG, possibly the B?
Unless your car had some electrical mods.?
http://www.theminifo...ad81cb90018.jpg
I reckon I bought an MG version.
Posted 23 May 2021 - 05:42 PM
Quite funny really - if you look over at the MGB forum they're all equally confused about the same issue!
Posted 24 May 2021 - 09:33 AM
Posted 24 May 2021 - 10:21 AM
Apologies, I've just been to the shed for a look, 1 and 3 are linked (permanent live to switched live) on my boxes, not a full bus bar so to speak
Ah OK - thanks for checking that out.
