Dash Panel 2/3 Clock Offset Speedo Rhd Fitting
4 replies to this topic
#1 primrose8
primrose8
  • 183 posts
Posted 22 May 2021 - 03:49 PM
Hi just bought the standard dashpanel from Minispares, it’s just a bit of vinyl covered cardboard, I thought it would be simple to fit but seems way too big to get in, do I need to remove the clocks ? or am I missing something?? Does anyone have any experience fitting them? Any advice would be very welcome!
#2 primrose8
primrose8
  • 183 posts
Posted 24 May 2021 - 03:38 PM
Maybe someone could post a pic of how it should look? It’s the triple clock with 2/3 dashpanel, I think there meant to be a shelf as well?
#3 sonscar
sonscar
  • 3,031 posts
Posted 25 May 2021 - 06:41 AM
My original one fits like a badly fitted jumper.Years of use have creased the inner card but you have to push it in where it sorta wedges in place held by the eyeballs and the flat that wedges behind the clocks.The shelf is covered in some grained vinyl over some similar cardboard.Steve..
#4 primrose8
primrose8
  • 183 posts
Posted 27 May 2021 - 08:09 PM
Hi Steve thanks for that! I’ll be having another go at it at the weekend! It just seems a lot bigger than the gap it fits in, do t suppose you could add a pic of yours?
Anthony
#5 sonscar
sonscar
  • 3,031 posts
Posted 28 May 2021 - 12:29 PM
My dash has some non standard wiring behind it which causes the cover to stick out and not tuck behind the instruments so neatly but here it is,the card backing is badly broken so it looks terrible.Steve..Attached File  IMG_20210528_121719.jpg   51.27K   2 downloadsAttached File  IMG_20210528_121706.jpg   50.47K   1 downloads
