Best Way To Remove Old Underseal ?
9 replies to this topic
#1 eebee
eebee
  • 44 posts
Posted 23 May 2021 - 05:46 PM
My ‘64 850 has suffered bodgery in the distant past. Areas such as the boot floor seem to be sound but covered in thick tar-like underseal. Should I use heat & a scraper or is there a better way ?
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 23 May 2021 - 06:04 PM
Ive used heat and a scraper very successfully in the past - but others may suggest better ways.
#3 Tupers
Tupers
  • 4,148 posts
Posted 23 May 2021 - 06:30 PM
Hot air gun and scraper is about the best was to get the bulk.
You can wipe away the excess with a rag soaked in paint thinners, get yourself a mask though it gets very stinky.
#4 eebee
eebee
  • 44 posts
Posted 23 May 2021 - 06:49 PM
Sounds like a rainy day job...
Thanks.
#5 TXCollector
TXCollector
    Just On Tickover
  • 7 posts
Posted 24 May 2021 - 08:01 AM
Before you have a go with the heat gun just try it with a scraper first, a lot of underseals dry-out and come off quite easily with a scraper and wire brush, as soon as you put heat near it it'll just soften and become a right royal pain in the ass to get off!
Wear good eye protection too as those little chips of underseal are a bugger. :shades:
It's a damn messy job whichever way it goes - good luck! :D
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 24 May 2021 - 08:24 AM
I've not tried it (yet) but one that has been suggested to me in the past is to get some of the pipe-freeze spray that plumbers use, which makes the underseal brittle so it just chips off easily.
#7 RooBoonix
RooBoonix
  • 1,225 posts
As said above, some underseals go almost brittle over time so you can chip them off with a hammer and scraper in quite big chunks. I used an MBX tool on mine which is like a rotary wire brush/bristle tool which worked well on the underseal on my car which was still quite rubbery and was a nightmare to get off with a scraper. The tool made light work of it, but it made a right mess.
My car/shell is on a rollover jig though, I'm not sure I'd want to be laying under a car with an MBX tool spinning at couple of thousand RPM...
#8 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 24 May 2021 - 09:22 AM
For the tar like bitumen in the car I used an old wood chisel that I'd resharpened and used with a hammer, it's effective but use caution not to punch holes in the floor.
For the underseal I used thinners and a paintbrush to spread it out, then hold a rag against it to burn the underseal off.
Alternatively use a wire wheel on the grinder
Edited by cal844, 24 May 2021 - 09:24 AM.
#9 eebee
eebee
  • 44 posts
Posted 24 May 2021 - 08:40 PM
Thanks all. It’s worst in the boot area but seems to either chip off with a paint scraper or stay tar-like, which does eventually clean off with white spirit. The underside of the new floor pans has all been coated in it too; a horrible job to be done piecemeal as my sanity allows ! Am finding areas of filler under it though...
#10 MatthewsDad
MatthewsDad
  • 814 posts
Posted 24 May 2021 - 09:32 PM
It's a soul destroying job, whichever technique. A little at a time and a cuppa in between is the best option.
