Exhaust Valve Inserts
Posted 26 May 2021 - 11:10 AM
Posted 26 May 2021 - 11:47 AM
Fit these;-
I haven't looked into what they are made from. I think sometimes one can tie themselves in knots looking too deep.
Posted 26 May 2021 - 12:09 PM
Yea I made the mistake of googling insert material. Way more info than I probably need. I have an old big valve longman head that I have been putting off having inserts put in as I was concerned about cracking occurring between the inlet and exhaust.thks
Posted 26 May 2021 - 12:43 PM
How much use does it get?
Cost of the inserts & machining will buy quite a bit of fuel additive.
Posted 26 May 2021 - 12:53 PM
Don’t do it.
if you want inserts on a head like that you really need a very clever person who will actually cut out both seats and fit a double one.
one issue cost.
just use it and add additive.
Posted 26 May 2021 - 01:58 PM
Bear in mind that your seats may not be in such good nick anyway - there's only so much that lapping and relapping can do. So if your seats need recutting/guides need replacing/guide seals need replacing/you're having porting work then it's worth doing alongside.
