Hi guy's
While my gearbox was out I found the rear bush which holds the rear of the gear selector secure was totally collapsed or at least missing all the rubber and only had the inner steel tube rattling around in a larger outside steel tube.
I ordered a new bush. How on earth is it possible to remove the outer steel tube from the alloy diff housing. It looks like it is factory pressed and never to be separated again?
Thanks Brad
rod change selector bush.jpg 73.92K
2 downloads
rod change selector bush1.jpg 27K
1 downloads
