Starter Solenoid Issues ..... Again !
6 replies to this topic
#1 JeremyduP
JeremyduP
  • 46 posts
Posted 06 June 2021 - 04:23 PM
Having been through 4 or 5 ‘Lucas’ push button starter solenoids, I decided to buy a Durite one in August last year. It has now failed just like the others.
All of a sudden after a drive, either immediately after or the next day, the car won’t start. Not even a click. Even the pushbutton does nothing. Of course shorting across the terminals with a screwdriver gets the car started. Replacing the solenoid always fixes the issue for a while.
Does anyone have any thoughts?
#2 nicklouse
  • 18,730 posts
Posted 06 June 2021 - 05:21 PM
Sounds like the quality is no longer there.  All it is is a very heavy duty relay.
I still have a 20-30 original solenoid on my car.
#3 Chris1992
Chris1992
  • 2,022 posts
Posted 07 June 2021 - 08:26 AM
Interesting that the Durite one failed too. I went through about 4 of the Lucas ones before trying the Durite one and the difference in quality was immediately noticeable. I kept that same solenoid on my car until I eventually swapped to a 1275 with a pre-engaged starter.
#4 JeremyduP
JeremyduP
  • 46 posts
Posted 07 June 2021 - 02:35 PM
I took the Durite one off this morning. It has a heavy rattle when you shake it. Not good.
#5 sonscar
sonscar
  • 3,062 posts
Posted 07 June 2021 - 05:14 PM
Long shot but is there sufficient current to pull it in and hold it when starting leading to overheating?Or is it indeed Tat?Steve..
#6 richmondclassicsnorthwales
  • 942 posts
Posted 08 June 2021 - 08:32 AM
It really is just about the quality of the internals - they burn out.
Try a Britpart 13H5952 starter.
One - they are fitted to Land Rovers and two - they carry a 2 year warranty. I can vouch for them,
I had the same issue as you, then fitted one to our Midget from Britpart.
No bother since
#7 JeremyduP
JeremyduP
  • 46 posts
Posted 09 June 2021 - 04:06 PM
Free replacement Durite installed. Let’s see if it can best the record for lasting more than 20 starts.
