1970 stock drum brakes with car been in long time storage, brakes havent been used for over 15 yrs.
One front cylinder had leaked, rest of brakes, cylinders/shoes etc look newish to the eye.
4 new cylinders fitted to front end. The right side front (that had the leaky cylinder) had the shoes and drum cleaned as best you can.
Removed master cylinder, drained, Refitted and bled entire system until new fluid at all corners.
It still takes one pump to get full pedal. I am sure there is no air in system.
Front wheels will lock via the adjuster so set them correctly but rear the wheels will NOT lock via the adjuster. However if I pull the handbrake on 3/4 way it removes the need to pump the pedal suggesting the rear brakes are the cause of the pump.
The rear shoes look meaty but I suspect the rear drums have been turned and perhaps standard shoes don't reach correctly. Before I order new parts from the other side of the world can you please advise.
1. What is the inside dia of a standard brake drum
2. How thick (including the metal) is a new standard rear brake shoe. I seem to remember you could order oversize brake shoes to fit a turned drum.
With these measurement I can judge if either new shoes/ new drums or both is needed so I can get a tight adjustment and hopefully remove the pump the pedal situation.
Also I notice the car pulls left slightly if I pump the pedal once and brake firmly. I suspect this is due to an oil soaked brake shoe on the right front still containing some fluid.
Do you suggest replacing the front shoes will eliminate this or perhaps a good drive up and down a steep hill with lots of firm braking to try and burn the fluid out/bed the shoes in etc?
Thanks in advance
