What 7.5" Brake Callipers Fit Under 10X4.75 Rose Petal Wheels?
15 replies to this topic
#1 JDImini
JDImini
  • 679 posts
Posted 12 June 2021 - 07:28 PM
I've just bought some 10" rose petals and Yokohama A032R tyres and they are currently 4 expensive paper weights as they won't fit over my 7.5" disc AP brake callipers :(
The wheels came with spacers and they didn't solve the problem
Can anyone suggest what callipers will work
Darren
Edited by JDImini, 12 June 2021 - 08:12 PM.
#2 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 13 June 2021 - 08:40 AM
What’s hitting, the weights? You might have to move the weights inwards if it is. They should fit over 7.5 callipers.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,063 posts
  • Name: Neil
Posted 13 June 2021 - 11:02 AM
This, they should fit right over without any issues. Are you sure you have 7.5” and not 8.4”??
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 13 June 2021 - 01:55 PM
Where did you buy them?  The MiniSpares ones should fit fine, the JBW ones may not.
#5 luismx123
luismx123
  • 525 posts
Posted 13 June 2021 - 03:52 PM
Mine only fit with the front spacers. The wheels rub on the metal around the bleed nipple of the brake calipers.
I have the minispares rosepetals and 7.5 cooper s brakes.
I had to reposition the balance weights to the inside of the wheels close to the spokes.
#6 JDImini
JDImini
  • 679 posts
Posted 13 June 2021 - 09:44 PM
Hi All, thank you for the help and advice, just to answer a few of the questions I bought the wheels from Swiftune although they had MiniSpares tape on the box just because MiniSpares didn't have any and yes they are def 7.5 cooper s brakes.
With some better light and and a bit of renewed vigour this afternoon I tried again and typically the wheel I had picked up originally had 4 weights and it was only these that were catching on the calliper, I thought the back of the bleed nipple was rubbing on the inside edge of the wheel but thankfully it wasn't. I fitted one of the other wheels that only had one small weight and this was just rubbing so with  a bit of time and a file I have smoothed the calliper off so it doesn't catch the weight at all.
However, I'll take all the wheels back to the tyre place and get them to relocate the weights
Thanks once again for all you help
Darren
#7 dodge44
dodge44
  • 53 posts
Posted 14 June 2021 - 07:56 AM
The problem has been caused by the switch from Lead to Zinc balance weights. You now often have to use multiple smaller weights on the inside rim instead of a single weight as the new weights are that much 'bulkier'.
Roger
#8 Dusky
Dusky
  • 5,322 posts
Posted 14 June 2021 - 10:22 PM
Remove the weights and get some dynabeads. Especially with the big 10" tires you ll like them.
#9 I hate Brian
I hate Brian
  • 782 posts
Posted 15 June 2021 - 06:35 AM
hi Dusky what are Dynabeads ?
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 15 June 2021 - 06:49 AM
Google is a wonderful tool:
https://www.dynabeads.co.uk/
#11 I hate Brian
I hate Brian
  • 782 posts
Posted 15 June 2021 - 06:53 PM
I did Google eventually lol
#12 JDImini
JDImini
  • 679 posts
Posted 15 June 2021 - 09:03 PM
Roger
Thanks Roger for the insight
#13 JDImini
JDImini
  • 679 posts
Posted 15 June 2021 - 09:11 PM
Hi Dusky they look interesting
#14 smurfomatic
smurfomatic
  • 461 posts
Posted 16 June 2021 - 07:29 AM
Out of interest, what amount of dynabeads did you use for 10" tyres? Had a quick look on their website but couldn't find any guidance for wheels this small!
#15 Dusky
Dusky
  • 5,322 posts
Posted 16 June 2021 - 07:58 PM
2 ounces should be enough. Even one ounce might be enough but I'd rather use a bit more than too little.
