Hello
I thinking to buy this plug, but my engine/gearbox is completely assemled.
Is it a chance to fit the plug without disassembling the whole unit ?
HPS6 - Mini magnetic oil trap for gearbox (minispares.com)
Posted 13 June 2021 - 10:29 AM
Hello
Posted 13 June 2021 - 11:08 AM
It is possible. Some exhaust systems will be in the way though.
just read the instructions very carefully or you may need to take the engine out and split it.
Posted 13 June 2021 - 11:29 AM
Thank you ! Fortunately the engine is not in the car yet, so it seems a straightforward task ![]()
Posted 14 June 2021 - 05:44 AM
What are the pros/cons of that plug if there is any ?
Posted 14 June 2021 - 08:43 AM
Pros.
it can reduce the magnetic parts reaching the pump.
cons
does need regular inspection and cleaning.
can be hard to access.
also the magnetic plug can easily be replace with a standard one or a temp sender.
