Carburettor
Best Answer cal844 , 16 June 2021 - 08:59 AM
Remove the engine steady bolts to let the engine come forward Go to the full post
Posted 15 June 2021 - 07:04 PM
Posted 15 June 2021 - 07:16 PM
can you post a picture - difficult to see what the problem is without one
Posted 15 June 2021 - 07:49 PM
Posted 16 June 2021 - 07:16 AM
Posted 16 June 2021 - 08:07 AM
If you're still unable to get it off, I personally find it easier to undo the manifold nuts and remove the whole thing with the manifold included.
Posted 16 June 2021 - 08:59 AM Best Answer
Posted 16 June 2021 - 03:13 PM
What manifold do you have?
As Chris1992 says - Probably easier to remove it with carb attached.
Posted 16 June 2021 - 03:35 PM
You can use two nuts locked together and remove the manifold studs so it will clear.
Posted 16 June 2021 - 04:05 PM
Only any good if he has separate inlet and exhaust manifolds though. otherwise you're into disconnecting the exhaust too
Edited by GraemeC, 16 June 2021 - 04:06 PM.
Posted 16 June 2021 - 06:23 PM
Not sure if you're trying to remove carb & inlet manifold together?
Take studs out as above
Posted 16 June 2021 - 07:33 PM
Posted 16 June 2021 - 09:28 PM
Ah yeah that's a good point actually. I've never owned a mini with the original intake/exhaust combo manifold so I sometimes forget they exist!
