Does anybody have a video link showing how to check the timing on a stock 1970 850 using a timing light.
I just want to check it, there is no issues and the car is running fine.
Posted 17 June 2021 - 07:01 AM
Posted 17 June 2021 - 09:15 AM
Edited by cal844, 18 June 2021 - 09:12 AM.
Posted 18 June 2021 - 03:22 AM
There is no link posted?
Tried youtube, can only find using crank pulley timing marks (later model).
Posted 18 June 2021 - 05:18 AM
Posted 18 June 2021 - 09:11 AM
Posted 20 June 2021 - 06:33 AM
I would prefer a vid showing the entire process from start to finish on a stock 850, might be asking too much.
Posted 20 June 2021 - 03:45 PM
Posted 21 June 2021 - 10:56 PM
That video is wrong model as it uses pulley marks, mine has none.
Thanks anyway
Posted 22 June 2021 - 09:24 AM
Look at the flywheel end of the motor, there should be markings on the flywheel viewed with a mirrorThat video is wrong model as it uses pulley marks, mine has none.
Thanks anyway
Edited by cal844, 22 June 2021 - 09:25 AM.
Posted 22 June 2021 - 12:48 PM
Posted 22 June 2021 - 01:16 PM
Edited by ACDodd, 22 June 2021 - 01:18 PM.
Posted 24 June 2021 - 01:09 AM
Great info, Torado99 you are right I missed the bit with the mirror in that the first time.
Thanks guys I'll have a go. Yes I have a timing light.
