New Duplex Chain Too Loose
11 replies to this topic
#1 johnR
johnR
  • 2,302 posts
Posted 27 June 2021 - 09:40 PM
When I first rebuilt my 1293 I noticed that the new duplex chain was more loose than I thought it should be. In order to remove any possible cause of a repeat of my subsequent crank bearing issue I'd like to remove this slack. Does anyone in the UK offer oversized sprockets?(I see MiniMania offer various sizes but quite expensive)
Edited by johnR, 27 June 2021 - 09:41 PM.
#2 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 27 June 2021 - 10:06 PM
Use a tensioner
#3 Spider
  • 15,146 posts
Posted 28 June 2021 - 12:08 AM
The over-size sprockets has me curious. Do you have a link ?
I'm not sure if you did so, however, when fitting a new Chain, it's also necessary to fit new Sprockets too.
#4 imack
imack
  • 2,207 posts
Posted 28 June 2021 - 05:09 AM
Here you go, I saw it a few years ago on YouTube.
https://www.minimani...us-Applications
#5 Spider
  • 15,146 posts
Posted 28 June 2021 - 05:26 AM
Cheers !
Ha !!   Rollmaster - Made in Australia :shades:
#6 johnR
johnR
  • 2,302 posts
Posted 28 June 2021 - 10:53 AM
Yes - it was the Minispares duplex kit - I presume the block has been line bored at some point without keeping the centres at the same distance
#7 johnR
johnR
  • 2,302 posts
Posted 28 June 2021 - 10:56 AM
Use a tensioner
the problem is that there isn't a made-for-purpose duplex tensioner and I've heard that the simplex one's pads can quickly wear on a duplex chain so I'd rather solve the issue once and for all.
#8 johnR
johnR
  • 2,302 posts
Posted 28 June 2021 - 10:59 AM
Cheers !
Yes, which means high postage costs and then you have to fit it the other way up!
#9 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 28 June 2021 - 11:50 AM
Use a tensioner
There are plenty of minis out there using a tensioner on duplex, including mine. They will naturally wear a groove in the middle, however the pad will work on both parts of the chain :) The other option is to remove the duplex and replace with an IWIS simplex.
#10 Nial81
Nial81
  • 32 posts
Posted 28 June 2021 - 02:28 PM
I'd try a different kit, I sent back a mini spares kit that wasn't fit for purpose for another reason. I then got the MED duplex kit I had no problems, I also noticed the chain on the MED having no slack when the mini spares chain did.
#11 Spider
  • 15,146 posts
Posted 28 June 2021 - 09:35 PM
The oversized sprockets I have to say, concern me, not in a big way, but in order to 'over-size' them, the diameter of one of both sprockets is obviously increased and so the pitch between Sprocket Teeth would also be bigger, this would have to lead to a much quicker wear rate of the assembly and regardless the brand of chain, premature stretch. Noted on the Rollmater website they do state that 'oversize Isws Chains aren't available'. I'm not sure these would be a good idea,
Use a tensioner
I've been running Duplex Chains and the Simplex Tensioner (original Leyland / Rover ones) in many many Cars now over the past 35 odd years now and would be well over 500 000 km collectively, with the longest running one having done circa 200 000 km + (and seen 3 x engine rebuilds). I'm yet to have any trouble with any and I'm yet to replace one.
#12 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 29 June 2021 - 08:58 PM
Mine came with the wrong chain .. might be a problem at the suppliers and MS still have some in the stores.
Probably should have added they sent the correct chain immediately after I contacted them.
Edited by gazza82, 30 June 2021 - 05:49 PM.
