96 Jdm Rover Auto Trans Question
9 replies to this topic
#1 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 11 July 2021 - 07:15 PM
I have a 96 Japanese Rover Mini, automatic transmission.
Under normal acceleration, shifting between gears is very quick (low rpm ranges) and I get into 4th gear at 40km/h. Shifts from 3rd to 4th is almost immediate after the shift from 2nd to 3rd. Shifts are relatively smooth, but definitely not great, or where I would like them to be.
I just performed an oil change with 10w/40 MA2 spec oil. Car has 98000 KM on it.
How can I get more RPMs in each gear, and smoothen out the shifts?
#2 leyland73
leyland73
  • 158 posts
Posted 11 July 2021 - 07:18 PM
Check your oil, should be 10/40 ma2 semi synthetic
Its designed for motorbikes with wet clutches, ideal for our ap mini gearboxes.
#3 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 11 July 2021 - 07:43 PM
Post states that's the oil used.
#4 Homersimpson
Homersimpson
  • 835 posts
Posted 11 July 2021 - 07:52 PM
The OP stated 10/40 MA2 but not whether mineral, semi synthetic or synthetic.  I'm not sure what you would run in a mini automatic as its been years since I had one and oil technology has advanced so much.
#5 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 11 July 2021 - 08:22 PM
Ah, I thought MA2 oil was only available as a single type (semi synthetic).
I believe semi synthetic is what should be used, I may be wrong yet again though! What I will say though is avoid Halfords (overpriced) and also Euro Car Parts with the Triple Qx stuff (better quality out there).
Apologies and regards (I should really read posts!)
Cal
Edited by cal844, 11 July 2021 - 08:24 PM.
#6 mab01uk
mab01uk
  • 12,514 posts
Posted 12 July 2021 - 08:16 AM
Some of the info on the 'Automatic Mini Register' forum below may also help you:-
https://autominiregi....proboards.com/
#7 Dusky
Dusky
  • 5,322 posts
Posted 12 July 2021 - 08:39 PM
Iirc you can adjust the bands on an auto mini. Which is what I would call the governor on my American transmissions.
Edited by Dusky, 12 July 2021 - 08:40 PM.
#8 hennasxi
hennasxi
  • 117 posts
  • Local Club: LSMOC
Posted 13 July 2021 - 10:25 PM
You can adjust the kick down control lever to make it hold the revs more and also kick down sooner for better acceleration.   Mine used to be into 4th by 25 mph, but now holds onto 3rd until around 35mph (or more if I have my foot down), but if driving gently will goto into 4th sooner so its working really well.
#9 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 13 July 2021 - 11:31 PM
How do I do this?
#10 hennasxi
hennasxi
  • 117 posts
  • Local Club: LSMOC
Posted 20 January 2022 - 10:13 PM
Where the kickdown rod attaches to the throttle body you will see it has a thread and some small nuts.  You can adjust this to effectively make the rod shorter or longer, it won't adjust massively, but by making small adjustments and trial and error you should be able to tweak it to be closer to what you want.
How do I do this?
