How Can I Stop The Indicator End Rotating?
4 replies to this topic
#1 trashy
trashy
  • Just Joined
  • 30 posts
Posted 21 July 2021 - 03:12 PM
How can I stop the indicator end rotating on the stalk?  I assume that it should be fixed?  Mine rotates!
Attached File  stalk.jpg   124.68K   0 downloads
#2 Johnmar
Johnmar
  • Just Joined
  • 176 posts
Posted 21 July 2021 - 07:43 PM
Glue?
#3 surfblue
surfblue
  • 1,827 posts
Posted 21 July 2021 - 07:49 PM
It needs to push in for the horn to function so glue maybe not the best solution.
#4 Spider
  • 15,684 posts
Posted 21 July 2021 - 08:49 PM
My new one is doing the same, it's only been on the car less than a year and hardly had much use in that time. It's somewhat disappointing.
While the outer of the button does push in for the horn, there is an inner that holds it to the stalk. It's next to impossible to see. If you carefully pull the button out, you may need to remove the assembly to do that so you can feed the Horn Wire up the stalk, then put a drop of Superglue (just a small drop) on the stalk, then line up and refit the button, that should hold it for a while.
#5 trashy
trashy
  • Just Joined
  • 30 posts
Posted 22 July 2021 - 08:42 AM
Thanks guys, I'll have a play.
