65D Distributor - Timing Adjustment
2 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 221 posts
  • Local Club: Mainly Minis Montreal
Posted 21 July 2021 - 11:47 PM
Hi there!
Beginner question:
91 Carb Cooper with 65D electronic distributor with vacum advance.
After watching some videos on how to set the timing, I am unsure if this distributor has a mechanical advance or not. The car has no ECU as it is a carb'd
Asking to know if after setting the initial timing at idle with vacum unplugged, should I do the full vac advance adjustment as well on this distributor? Hopefully I am being clear.
Thanks for the help!
#2 Spider
  • 15,850 posts
Posted 22 July 2021 - 03:00 AM
It does have a Mechanical Advance mechanism.
Timing is usually set with the Vacuum Advance Disconnected.
It maybe a good idea after setting it, to check it for full advance and at what revs that occurs at.
#3 GermanMoreno
GermanMoreno
  • 221 posts
Posted 22 July 2021 - 03:52 PM
Yes that's exactly why I wanted to know, Thank you! :)
