Just purchased a 1993 Sprite 1275cc with a HIF38 carb. The exhaust cat has been removed before we purchased the car. The engine has what I think is an open loop catalytic converter system. This is my interpretation of the Haynes manual supplementary section. Can this system be removed and the connection points to the carb and engine blocked?
In addition it is fitted with Thermostatic vacuum pipes and valve in the thermostat housing but this fitting is broken. Can it be removed altogether without any detrimental effect on the engine.
many thanks
