Mates,
Got a 92 998 with a Weber DCOE 40 and FET intake. Engine/exhuast is stock except for an upgraded high flow muffler. Previous owner ran F8 45 idle jets in winter from Nov to April, and F8 40s from May to Sept is seems but he wasn't 100% about the summer ones or if this combo was ideal. With the 45s it ran decent (albeit taking 5 minutes or so to warm up and have the initial gas pedal blip clean up (just a slight bog down from idle to 1500rpm for the first 5 minutes warming up, which I assume is normal. It wouldn't bog down as long as I just gently gave it gas from 900-1500 though). Idling was around 900rpm and stabilized once warmed up.
I put in the 40s recently, and I am getting a bit more of a bog if I give it a good blip of gas while warming up, but then it cleans up beyond 1500-2000rpm or so. Seems like I have be much more gentle from 900-1500 in comparison to the winter jets. It does seem like a bit less power though, but seems to be idling smoother. Also, once the weather got warm, the engine starts to make a bit of a tapping sound, but now that seems gone with the summer jets.
MY QUESTIONS:
1. Does this set up seem good?
2. I'm just wondering if everyone does this (different idle jets for summer/winter) and if I am using the correct jets.
3. Also, is the stutter from 900rpm-1500 normal for first 5 minutes of warming up both in summer and winter?
4. In summer, should I try starting w/ no choke or half perhaps? It does start up okay, but not right away a does require a bit of pumping before and after ignition starts.
By the way, I live in a place with a quite hot summer, and a mild winter. Average coldest month is 9C (doesn't snow here) and average warmest is 32C.
Cheers in advance for any info mates!
