Fuel Leak From Inlet Manifold
11 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 24 July 2021 - 08:50 PM
Hello
1993 L reg SPI Cooper, Manual, RHD
I have had the engine out
Replaced all gaskets
Inlet manifold was sent away and refurbished
Lots more than this, but pretty much a top end rebuild
It's all back together
Tried starting it for the first time today
First time in about a year
Starter motor was fine
Almost fired
A small splutter
Battery died!
Recharged battery
Fettled on other stuff
Tried again
Again, starter motor doing its thing
This time, no flicker of a fire
Just endless starter motor
A smell of fuel
Dripping from the inlet manifold
Fuel was getting through to the injector
I suppose that's a good thing
But from there, it wasn't great
I've given up now
It's going dark
Working on the drive
The manifold gasket is new
I am sure I tightened the nuts onto the studs with some oomph
Might it just need oomph+ ?
Or is it possible to have misaligned the inlet manifold to the engine block / gasket?
I can't see how, but I won't rule out utter stupidity (on my part)
The inlet manifold, manifold gasket etc were dry fitted
No sealant
Just the gasket
Any ideas, suggestions?
Regards
Elwyn
#2 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 24 July 2021 - 08:59 PM
Sorry, I should have been clearer....the fuel leak was at the inlet manifold to manifold gasket junction on the far left hand "port" as you look from the front of the car into the engine bay
The brake servo side
#3 Pops_Guild
Pops_Guild
  • 363 posts
Posted 25 July 2021 - 07:05 AM
Sounds like it has not gone square-on. I assume the locator rings were in place and on correctly? I’ve seen ones that have been put in the manifold wonky prevent a good seal.
You do need to torque up the manifold nuts correctly. The ones in the middle are best done with the throttle body removed for access to them.
#4 humph
humph
    How bad can it Be?
  • 1,107 posts
Posted 25 July 2021 - 09:48 AM
Similar to above, my thoughts were;
  1. Were all faces cleaned and all remnants of old gaskets removed?
  2. Assuming you have the correct manifold studs (they're unique to injection cars) are they screwed in the full way?  If not then the manifold nut will ground on the non-threaded section, torque up & leave a gap.
  3. Are the locating rings in place? Are they square?
  4. Any high spots or thickness differences around the flanges of the inlet & exhaust manifolds that are stopping the inlet seating properly?
By the way how was the inlet manifold refurbished? And where did it go?
Edited by humph, 25 July 2021 - 09:49 AM.
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 25 July 2021 - 10:23 AM
Hello
That’s excellent stuff
Yes, the old gasket was completely removed. All surfaces were / are totally clean
I haven’t changed the studs. I didn’t do anything to them. Is there a torque setting to screw / wind them in all the way? Is there a torque setting for nuts, not that I think I’ll have room to get my torque wrench onto them. I’m sure I looked up the nut torque and it was quite low.
Locating rings. Now this is probably it. I don’t recall removing or refitting anything like that at all. Parts missing before and still now?
No high spots anywhere. I sent the inlet manifold away to a TMF member who does a lot of them. Vapour blasting, new parts, pressure tested before being sent back.
Studs, torque and locating rings.
That’s my focus
Mini Spares dot com again
In terms of getting the thing to sit square / properly aligned, is there a trick or will the rings pretty much do that for me?
Do the rings fit into the cylinder head or the manifold?
Tapped / knocked in?
Or a special mechanical tool?
Regards
#6 Elwyn
Elwyn
  • Just Joined
  • 365 posts
And yes, I’ll be removing the throttle body
#7 Pops_Guild
Pops_Guild
  • 363 posts
Posted 25 July 2021 - 10:38 AM
That was me :). I do SPi inlet manifold refurbs and other things as a hobby. I wrote the refurbishment guide that's pinned on this group too. Attached are some pics of Elwyn's manifold.
I haven't been able to get to my workshop to make more of the stainless pipes for a long while but hoping to do so in August. Lots of folks waiting on the DIY kits and for full refurbs.
Also just started a FB page > @ClassicMiniNLA
  • Attached File  6.jpg   62.93K   0 downloads
  • Attached File  1_sm.jpg   65.27K   0 downloads
  • Attached File  2_sm.jpg   65.62K   0 downloads
  • Attached File  3_sm.jpg   32.17K   0 downloads
  • Attached File  4_sm.jpg   74.56K   0 downloads
  • Attached File  7_sm.jpg   66.89K   0 downloads
#8 Pops_Guild
Pops_Guild
  • 363 posts
Posted 25 July 2021 - 10:44 AM
Hello
That’s my focus
Regards
If they were missing it sounds like they're your smoking gun. The locating rings are essential. I usually push them into the inlet manifold, no special tool, prior to fitting the manifold but you just need to make sure they're in properly...it'll be obvious if they're not square in.
Available from most of the mini spares places...
12G297 - Mini manifold locating ring (minispares.com)
GUG704053MG is the correct manifold gasket, if that's the one you have fitted then also makes sure the smooth metal side goes towards the manifold.
Roger
#9 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 25 July 2021 - 10:50 AM
Locating rings now ordered
Hoping there's only one smoking (or dripping) gun
Roger created a work of art and I b*llsed up hanging it on the wall (terrible metaphor)!
Edited by Elwyn, 25 July 2021 - 10:54 AM.
#10 humph
humph
    How bad can it Be?
  • 1,107 posts
Posted 25 July 2021 - 11:58 AM
Thanks, I only ask because I'm sure I will need mine doing at some point. I removed it a couple of years back and the pipes were all clear but a bit corroded.  I've read your how to thread before, but didn't realise you were taking orders, it's good to know. Is there a thread with prices somewhere?
#11 Pops_Guild
Pops_Guild
  • 363 posts
Posted 25 July 2021 - 02:23 PM
Unfortunately every SPi manifold will eventually need to get sorted, the pipes and core plugs on them are made from terrible quality steel.
I didn't really intend to do refurbs of other peoples manifolds, I just kind of fell into it. It's kind of cool to help folks get their Minis back to working condition again. The pricing depends on the manifold (assuming you wanted your manifold done) condition and how easy or nightmarish it is to do but generally I charge around £175 - £190. I would usually have some ready-to-go so could do them on an exchange basis, and that'll save £25 off the price. If you are on Facebook, then the "Classic Mini SPi" group is my usual stomping ground, I love TMF but I only pop in around once a week...FB is every day. There are plenty of posts from me there.
Ultimately if you're interested then message me here and we can chat in more detail. thx
#12 MatthewsDad
MatthewsDad
  • 819 posts
Posted 25 July 2021 - 07:49 PM
  • Were all faces cleaned and all remnants of old gaskets removed?
  • Assuming you have the correct manifold studs (they're unique to injection cars) are they screwed in the full way? If not then the manifold nut will ground on the non-threaded section, torque up & leave a gap.
  • Are the locating rings in place? Are they square?
  • Any high spots or thickness differences around the flanges of the inlet & exhaust manifolds that are stopping the inlet seating properly?
... you do a fantastic job on the manifolds, my new one looks great and works a treat. Thank you.
