Mpi Side Mount Radiator
6 replies to this topic
#1 jsyjamie
jsyjamie
  • 76 posts
Posted 27 July 2021 - 01:56 PM
Hi all,
Due to going forced induction on my mpi engine and wanting to put an intercooler in the front I am side mounting the radiator.
My engine has a side mount turbo so I need an engine steady to the thermostat housing from DSN.
Attached File  received_1377907555928035.jpeg   48.33K   1 downloads
Does anyone know if this is possible as the engine steady I bought clashes with the alternator bracket? https://www.dsnclass...-big-bore-long/
Can I buy one of these and hope the spacer clears the bracket? https://www.dsnclass...retrosport-mpi/
Or shall I just grind a chunk out of the bracket?
I know the Jap spec minis have a similar set up...
Many thanks!
#2 tmsmini
tmsmini
  • 743 posts
  • Local Club: MOASF
Posted 27 July 2021 - 04:24 PM
As the thermostat housing is shifted/rotated on the JDM Minis, I am pretty sure the DSn version wont work.
We made a custom thermostat sandwich and top radiator bracket to fit this.
#3 jsyjamie
jsyjamie
  • 76 posts
Posted 28 July 2021 - 06:49 AM
That's what I thought...
Will PM you, thanks.
#4 whistler
whistler
  • 1,831 posts
Posted 28 July 2021 - 11:48 AM
You could use a water pump to bulkhead steady plus extra steady bars underneath, gearbox to rear of subframe.
. Have also seen extra forward steady bar fitted from front of subframe to speedo housing area.
#5 jsyjamie
jsyjamie
  • 76 posts
Posted 28 July 2021 - 12:43 PM
I wasn't aware of the water pump engine steady, thanks for that!
#6 nicklouse
  • 18,724 posts
Posted 28 July 2021 - 12:46 PM
Not too good as they put a lot of load onto the end of the bolts. This can cause the pump to move. Later ones did not have the locating dowls.
#7 jsyjamie
jsyjamie
  • 76 posts
Posted 28 July 2021 - 12:50 PM
That is a shame, any other options you can think of Nick?
