998, hs4 carb, standard air filer, cast manifold and peashooter, 64md dizzy and 12v electronic coil (been running since 07)
So far I’ve tried, full carb rebuild including float valve, jet (hs4 waxstat) throttle disk and spindle (couldn’t find any one to entertain replacing the bushes, but then didn’t seem worn) and needle (AAU fitted, to replace the slightly worn ADL that was fitted/originally tuned with, but is slight closer to the AAC needle fitted as standard below 3k).
8mm performance silicone hat leads, dizzy cap and rotor arm cleaned as they aren’t that old. And several sets of spark plugs (ngkbpr6es) As if it tune the carb with the lifting pin the plugs end up so black they are only fit for the bin, but if I tune it to the colour tune I’m stuck with the misfiring issue.
Mechanical fuel pump replaced 2019, but it only did 300 miles between mots for all of last year.
I thought I’d test the coil (GCL 143) as it getting on for 12 years old (replaced in 2009). From what I’ve found it should have a primary resistance of around 0.9ohms and secondary resistance of between 5 and 15k. I got 1.2ohms on the primary and 5.2k on the secondary.
So I took a punt and bought a brand new GCL 143 coil, Fresh out the box it tested. 1.6ohms on the primary and 4.6k on the secondary, worse than my old one. I’ve since fitted it and it’s made no difference, it’s still misfiring below 2k (idles fine all day long) until it’s warmed up enough to be driven. Other than the misfiring and the works when it wants to speedo, which is a spate issue, it drives great for a standard 998 providing you ignore it’s got a 4th gear (no pull in 4th with a 2.9 diff). Just it’s starting to be a bit of a pita and going through sets of plugs.
So is it my coil/s? (Can’t send the other one back) or something else?
