Airfilter - Offset Or Centre?
Best Answer barneyman , 12 August 2021 - 09:41 AM
many thanks all, food for thought for sure though at least we now know its offset not centre  :D
Go to the full post
13 replies to this topic
#1 barneyman
barneyman
  • Just Joined
  • 52 posts
Posted 10 August 2021 - 04:23 PM
It seems that it should be obvious but before I buy a new chrome assembly k&n air filter I need to be sure whether to purchase an offset or centre holed item?
I have attached some photos of the current casing we have plus filter, plus lid plus the underside...
Can someone put me out of my misery on this?
many thanks!
#2 Compdoc
Compdoc
  • 612 posts
Posted 10 August 2021 - 04:39 PM
If your replacement filter is a K&N pancake or cone filter that bolts to the carb mouth, then the offset hole allows the filter to sit a bit higher and stop it hitting the cross member when the engine moves back and forth. I would check with your supplier as it may vary with carb type. .
#3 cal844
cal844
  • 9,672 posts
  • Local Club: TFMOC
Posted 10 August 2021 - 04:40 PM
The chrome (cone/pancake type) are mounted with the 2 cross head screws that hold the carb elbow on.
Post a picture of the carb at the bulkhead side and the new filter.
If I'm fitting the cone or pancake type I fit the offset holed one to stop the bulkhead crossmember crushing it
Edited by cal844, 10 August 2021 - 04:42 PM.
#4 nicklouse
  • 18,767 posts
Posted 10 August 2021 - 06:22 PM
many thanks!
What is the problem? It sits where it should on the locating ring.
#5 nicklouse
  • 18,767 posts
Posted 10 August 2021 - 06:23 PM
many thanks!
Oh the pictures have nothing to do with the question.
neither just fit a KN element to that housing or if that is one in there already. Wash and re oil it.
#6 sonscar
sonscar
  • 3,084 posts
Posted 10 August 2021 - 06:35 PM
I'm with nick,keep the original airbox with replacement filter.Quiet,fits,filters properly and will supply all the air your motor can consume.I am an old codger.Steve..
#7 barneyman
barneyman
  • Just Joined
  • 52 posts
Posted 11 August 2021 - 09:00 AM
Hi all.
Thanks for the replies, always great to get different views.
Here are the photos requested...
we were thinking of getting the chrome (not cone) from k&n, so this one which is the centre option.
https://www.minispar...px|Back to shop
we were hoping to eek out some more performance and maybe a better look though I appreciate that is open to opinion!
#8 timmy850
timmy850
  • 3,422 posts
  • Local Club: MITG
Posted 11 August 2021 - 09:12 AM
You need the filter to be offset upwards like this (the holes are offset downwards) so that the filter doesn't hit on the bulkhead
I put a cone K&N on my HS4 998 mini. Probably didn't make it any faster but it did sound great
Edited by timmy850, 11 August 2021 - 09:13 AM.
#9 cal844
cal844
  • 9,672 posts
  • Local Club: TFMOC
Posted 11 August 2021 - 09:16 AM
You will need the offset filter for that set up, you need to remove that elbow from the carb and use the 2 screws to fit the filter.
Personally I'd use the standard filter box and drill the holes as required for better flow.
On my car I have to remove the dashpot piston from the carb, fit the filter box and then refit the piston.
#10 KTS
KTS
  • 2,483 posts
Posted 11 August 2021 - 10:11 AM
might be worth considering one of these as an alternative to the pancake filter - £15 more than the K&N pancake, but does include a stubstack
https://www.med-engi...ub-stack-system
#11 JXC Mini GT
JXC Mini GT
  • 859 posts
Posted 11 August 2021 - 10:48 AM
I would use the standard filter box and drill the holes as per Calver Tuning recommendation and fit a K&N filter element.
#12 cal844
cal844
  • 9,672 posts
  • Local Club: TFMOC
Posted 11 August 2021 - 01:29 PM
That's the one! Thanks chief
#13 barneyman
barneyman
  • Just Joined
  • 52 posts
Posted 12 August 2021 - 09:41 AM   Best Answer
#14 johnR
johnR
  • 2,305 posts
Posted 12 August 2021 - 11:10 AM
I'm with the K&N filter in your (modded) standard airbox - a single carb will never look sexy like a pair does so go for the cheaper option. one of these finishers helps it look a little better.
