13 Inch Rostyle Wheels
10 replies to this topic
#1 bigrob
bigrob
  • 483 posts
Posted 13 August 2021 - 08:55 PM
Evening all.
I've seen 12 inch rostyles fitted to mini's, but I've never seen the 13 inch midget wheels fitted.
Does anyone have any photos please?
Cheers all
#2 nicklouse
  • 18,724 posts
Posted 13 August 2021 - 08:57 PM
The ET will be incorrect and give poor handling.
#3 bigrob
bigrob
  • 483 posts
Posted 13 August 2021 - 09:11 PM
I don't know a great deal about the science behind it, but most 13x6 minilites I've seen are Et15
The rostyles are narrower and have an offset of Et24(ish) which puts the inner face in a very close position to most after market 13's.
I suppose all that suggests though is, yes it will fit, but doesn't say much else
#4 71Pickup
71Pickup
  • 94 posts
Posted 14 August 2021 - 06:15 PM
You can get them banded inside or out if required to make them fit and get the et you want
#5 Maccmike8
Maccmike8
  • 1,101 posts
Posted 14 August 2021 - 06:45 PM
Aluminium?
#6 GraemeC
GraemeC
  • 7,446 posts
Posted 14 August 2021 - 06:51 PM
Rostyles are steel
Banding them to correct ET would be a very odd thing to try. To keep them the same width you’d need to band one side and reduce the other. And as we’re only talking a few mm it wouldn’t be that easy.
if you change the width then you’re just making more compromises.
#7 71Pickup
71Pickup
  • 94 posts
Posted 14 August 2021 - 07:12 PM
They are steel and anything is possible but not necessarily worth the effort
#8 bigrob
bigrob
  • 483 posts
Posted 14 August 2021 - 07:47 PM
To keep the width but change the offset would be basically re-rimming them. Not something I want to do.
Is the offset that off then? I used an online visual tool and it didn't look that bad
#9 bigrob
bigrob
  • 483 posts
Posted 14 August 2021 - 07:51 PM
Compared to the et35 of the 10x4.5 steels, the inner face sits in the same place, and the outer is just an inch further out
#10 Chris1992
Chris1992
  • 2,022 posts
Posted 14 August 2021 - 09:51 PM
Daviewonder on here has has some of the 13" Rostyle wheels banded to 13x7 and they look great. There a few photos on his build thread here: https://www.theminif...-project/page-8
I also had a set of Austin Healy Sprite steel wheels banded to 13x7 which I still have in the shed. Any competent wheel bander can alter offsets by removing the centers from the hoops and rewelding them in the desired position. I would recommend Banded Wheels Essex as he has been doing this for decades, and did a lovely job on mine.
#11 bigrob
bigrob
  • 483 posts
Posted 14 August 2021 - 10:25 PM
Thanks Chris. Shame there's no pictures of them fitted. Yeah I've only heard good things about Banded Wheels Essex.
I'm unsure as of yet.
I'm buying some 10 inch wheels from someone here, but the real appeal of the 13 inch rostyles is that they're almost disposably cheap
