Carburettor Leak
#16
Posted 05 September 2021 - 01:50 PM
#17
Posted 05 September 2021 - 04:49 PM
#18
Posted 06 September 2021 - 08:18 AM
Thanks everyone. The carb is off - bit of a faff getting the lower two nuts off, but got there in the end.
Have to say - I'm not looking forward to putting them back on!
Just waiting for the gaskets etc to be delivered
#19
Posted 29 September 2021 - 08:03 AM
Hi,
Just thought I'd ask if anyone knew where to get the WZX1099A kit from currently. I've tried Mini Spares and a few others and they have been out of stock all month.
Also the WZX1099A just has a single ring for a seal, whereas the WZX1100A (which somebody suggested on this thread - although I believe that is for an SU carb, not a HIF) has 3 or 4 gaskets in the kit - is the single ring seal with the WZX1099A
ok?
#20
Posted 29 September 2021 - 10:00 AM
Treat yourself to a quality slim 1/4 inch drive socket set for those pesky hard to reach nuts n bolts.Steve..
#21
Posted 30 September 2021 - 02:44 PM
Hi,
ok?
just giving this a nudge - any thoughts anyone?
#22
Posted 30 September 2021 - 03:29 PM
Have you tried Burlen Fuel Systems, they are the owners of the SU name and supply just about everything.
#23
Posted 30 September 2021 - 03:42 PM
Will have a look. Are Hiff and SU carbs the same - or different manufacturers/different carbs?
#24
Posted 30 September 2021 - 03:46 PM
also for my hif 44 carb do I need WZX1099A or WZX1100A?
#25
Posted 30 September 2021 - 06:49 PM
HIF is a Model type of an SU. There's a few models in SUs, mostly related to different eras of them.
#26
Posted 01 October 2021 - 07:24 PM
As Moke says, the SU carb has improved over the years defining manufacture to make them the most easily accessible and repairable with simplicity - believe it or not !!
They are an easy carb to work with, and I can say all gaskets and seals readily available for repair
Early SU carbs were very brass and aluminium orientated, nowadays, they are have easily replaceable parts
HIF are just a bit of a bugger where to do the job of fitting new floats, valves and filters, you need to be able to see them, as the old SU were all up top in the float chamber.
Additionally, trying to work on a HIF on the car, and when you lose a screw, it's gone for ever, normally falls where it shouldn't and against all sods laws
#27
Posted 09 October 2021 - 07:50 PM
#28
Posted 09 October 2021 - 09:21 PM
#29
Posted 10 October 2021 - 04:34 AM
Thanks so far.
So presumably the 1st thing I need to do is remove the entire Carb?
Any hints or tips on the best way of doing this? It all looks a bit tight down there! Not a lot of room to work.
Once the carb is out, what is the next step?
Depending on my mood or the amount of patience in the tank, sometimes I remove the carb/inlet as an assembly. The 4 nuts are far more easy to access and I’ve never had a leak from the manifold gasket.
#30
Posted 10 October 2021 - 10:41 AM
http://sucarb.co.uk/...small-bore.html
Seems like they are out of stock as well
You could just replace the main bottom seal - at least that could get you out of the myer for now
Edited by richmondclassicsnorthwales, 10 October 2021 - 10:45 AM.
