Carburettor Leak
#31
Posted 10 October 2021 - 11:42 AM
Posted 10 October 2021 - 11:50 AM
https://www.ebay.co.uk/p/1592411355
#33
Posted 10 October 2021 - 12:18 PM
Yes, That will do the job, they would normally come in a sealed bag bearing SU Carburetters in blue lettering
#34
Posted 10 October 2021 - 08:08 PM
https://www.ebay.co....0.c100930.m5375
Do I need all these extra seals and gaskets, or should i just go with the cheaper one that gives me the seal for the bottom of the carb?
#35
Posted 10 October 2021 - 09:27 PM
#36
Posted 23 October 2021 - 03:49 PM
I have noticed (and it was evident before also) that there is a slight lag, in all gears when you try to accelorate hard, just pauses and then goes...any ideas?
#37
Posted 23 October 2021 - 04:00 PM
Carbs back on and all good.
Lean running condition, try a half turn richer
#38
Posted 23 October 2021 - 04:24 PM
#39
Posted 25 October 2021 - 06:12 PM
Thanks, dumb question....what do i turn, and what way?
Anyone got an easy answer to this?
#40
Posted 26 October 2021 - 05:22 PM
Ok so I have found out there is a screw to turn on the carb to increase or decrease the amount of fuel. But before I start messing with this.......
See attached photo of my spark plug - does it look like the mix is too lean at the minute, or just spot on (by the colour of the end of the spark plug)?
If its looks spot on - by increasing the mixture, wont I just be making it too rich?
Also, if you see that photo of the dash pot needle - to me, it looks bent, or out of line. Is it supposed to be like that?
Could this be causing the pause in acceleration?
#41
Posted 26 October 2021 - 05:29 PM
some better photos of the spark plug..........mixture too lean?
#42
Posted 26 October 2021 - 06:35 PM
#43
Posted 26 October 2021 - 07:06 PM
That needle looks bent to me, best to remove it and check it on a flat surface
Will do. Not sure if the needle is bent or actually not sitting level at the base. If you look at the base of the needle to the left, it looks like its not sitting flat/flush?
Any thoughts on the spark plug colour indication too rich / too lean?
#44
Posted 26 October 2021 - 09:44 PM
#45
Posted 27 October 2021 - 09:28 AM
Is the needle a swinging springy one?if so it looks OK.Plug colour cannot be relied on unless checked after a reasonably hard run,and then it is not an exact science.Steve..
I'll get the dash pot of again a little later and have a look. From memory I think it is a springy one....but will double check.
Is there a better way to check the fuel mixture?
