Engine Removed, What Should I Replace While It's Out
6 replies to this topic
#1 R89Powell
R89Powell
  • 11 posts
Posted 22 August 2021 - 06:42 PM
Removed the 998 engine out of my mini today and was wondering what people suggest would be worth replacing while the engines out ? As it will be out for sometime as the rest of the restoration is done.. was thinking clutch, waterpump timing chain etc? Thanks
Edited by R89Powell, 22 August 2021 - 06:43 PM.
#2 Spider
  • 14,867 posts
Posted 22 August 2021 - 07:22 PM
I'd suggest most Gaskets and Seals, Oil Pump as well as items you've already mentioned.
How many miles were on it and what issues did it have when you last drove it ?
#3 Merryck
Merryck
  • 339 posts
Posted 22 August 2021 - 07:39 PM
Core plugs!
I had one with a pinhole on my Midget and it was a right pig to sort. The thing would overheat and spit out all it's water, but only in certain circumstances and it turned out to be one of the core plugs. Rather than replace them they'd painted over them. They're cheap and it's an easy job.
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 22 August 2021 - 07:50 PM
The items you've mentioned and don't forget to renew engine mounts and stabiliser bushes.
Id also give the carb a clean up too whilst it's off the car, also consider a coolant syst flush and check the thermostat too
#5 johnR
johnR
  • 2,297 posts
Posted 22 August 2021 - 07:57 PM
Get a lighter flywheel if you've got the budget - really makes a difference to performance of a 998
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,036 posts
  • Name: Neil
Posted 22 August 2021 - 08:03 PM
Although not engine related but in a way it is, check the upper stabiliser mount / bracket on the bulkhead crossmember and also check the mounting point on the engine to ensure the thread is in good condition.
#7 croc7
croc7
  • 810 posts
Posted 23 August 2021 - 05:53 AM
This one of those questions that can lead to the answer, ‘If it ain’t broke, don’t fix it.’ However, I would approach it with the idea to replace items that would be a pain to replace with the engine in place as Spider suggested; seals, gaskets, water pump & oil pump. Maybe have peek at the rod change seal. Also would be tempted to refresh the head.
