Cover-Bottom-Gear Lever Housing-Rod Change
4 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 25 August 2021 - 08:28 PM
hi.
I'm refurbishing my rod gear housing
I found a small hole on the bottom cover
anyone know what it's is for or is it a defect?
water could probably enter I doubt though because it's facing down is it ti fill up with grease?
#2 nicklouse
  • 18,741 posts
Posted 25 August 2021 - 08:31 PM
It is standard.
#3 Spider
  • 15,223 posts
Posted 25 August 2021 - 08:35 PM
They all have that hole and I'm only guessing that hole was there to help in the factory get the cover on the right way around. I weld them up and seal the cover to the housing. I've had the one on my Moke like that for a while now and - touch wood - so far so good, even after a few deep creek crossings. I hesitated to make this move for a long while as it does mean any water that gets in elsewhere can't drain out. I'll add here that I do have a good sealing boot on the front too, where the Rod comes in to the shifter, but as yet, none on top where the gearstick fits.
#4 cristiano1968
cristiano1968
  • 444 posts
Posted 25 August 2021 - 08:50 PM
I see I'm also thinking of welding it up.so that no water gets in.
it has been on the road for 33 years with no issues 😀
#5 Ethel
  • 26,141 posts
Posted 25 August 2021 - 09:41 PM
I always assumed it was drainage. There's no gasket so it probably would fill up if you went fording. I made a dinky cover plate to go under the nearest two screws
