Back Of Engine Looks Wet
6 replies to this topic
#1 kiwimike01
kiwimike01
  • 53 posts
Posted 26 August 2021 - 12:01 AM
Hey guys I was poking around the engine bay today and down the back behind the exhaust manifold it looks wet. It looks like it might be coming from the tappet cover. I wiped some off with a rag and it looked like old oil and smelled a little like oil but not very strong. I'm also not sure how long it has been there as the car has been sitting for quite a while and I started it the other day but don't recall if it was there before that. Any help would be great.
Edited by kiwimike01, 26 August 2021 - 05:18 AM.
#2 gaspen
gaspen
  • 946 posts
Posted 26 August 2021 - 05:50 AM
"If it does not leak, it's not a Mini"
Possibly tappet cover gaskets leaking I guess
#3 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 26 August 2021 - 07:06 AM
Usual suspect as you have mentioned is the rocker cover gasket, its cork and they do "harden / rot"... I would replace it as a matter of course and make sure you clean everything spotlessly on the mating surfaces and make sure they are dry... I "glue" the gasket to the rocker cover so it comes off with the rocker cover when setting the tappets, and I do not fit the rocker cover until the gaskrt is firmly stuck to the rocker cover.
Dont over tighten the bolts / nuts or you can easily distort the "tin" rocker cover itself and that gurantees leaks.
Tappet chest covers are a suspect if its a 998 850, or an elusive S block. "Standard / Common" 1275 cc blocks did not have tappert chest covers
#4 kiwimike01
kiwimike01
  • 53 posts
Posted 26 August 2021 - 07:24 AM
Thanks for the replys. It's an 1100 engine and has tappet covers. Is this a must fix right now or will it be ok for a while until the engine gets pulled later on. It's not my daily drive just a weekend cruiser at the moment
#5 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 26 August 2021 - 07:42 AM
To me its not a must fix now job, just keep the oil topped up, and fill it slowly.... if it is the rocker cover gasket that will slow the leak down a bit.. at least as you fill it
#6 kiwimike01
kiwimike01
  • 53 posts
Posted 26 August 2021 - 08:41 AM
Great thanks for your help. On another note if I drain the coolant/water and leave it empty for about a week till a new radiator and water pump get ordered will it be ok or will it cause corrosion in the water jackets?
#7 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 26 August 2021 - 01:47 PM
A week or two should be fine.
