Just rebuild my Cooper SPI - virtually all new mechanical parts and it drives great except a sort of clicking / rubbing sound from the front off side wheel.
This only happens when turning right or when under load ( acceleration) turning left or coasting it goes quiet. The noise also seem to be proportional to wheel speed and not engine speed so suspect something on the drive shaft somewhere.
The car has just passed MOT where the tester gave everything a good pull and push to check for play etc - all seemed good.
I have used new inner and outer joints and and replaced with Timken bearings and the hub was tightned down to correct torque using the big washer first to ensure the bearing was correctly seated before final tightening of the hub nut.
any thoughts ?
