Just a quick sanity check
MG Metro CAM6232 unknown journal size etc as already installed Damaged Nose on crank
replacing with a CAM6232 OE crank no marks STD SIZE Mains and rod journals
Parts list
Crank
Main bearings STD
Big end Bearings STD
End float shims
Primary gear oil seal
Gasket set full
Flywheel
Clutch kit (as its out)
Oil Pump (as its out)
Water Pump (as its out)
