Need To Add Around 2-3 Mm To Wheel Arches
6 replies to this topic
#1 R32Egor
R32Egor
  • 277 posts
Posted 07 September 2021 - 08:24 AM
HI all,
Got standard minilites - 4.5 x 12 et35 with 165/60 r12 falkens fitted
The TUV here in Austria say they are not ok as they stick out about 2-3mm from the front standard plastic wheel arches.
Does mini spares or mini sport do a edging strip that fits the standard plastic wheel arches? I have had a look and not sure which might fit. This hopefully would fulfill the TUV requirements
#2 Ethel
  • 25,415 posts
Posted 07 September 2021 - 08:59 AM
2mm! That sounds extremely petty.
Couldn't you just put some packing between the arches & the body?
Rubber or PVC moulding???
#3 R32Egor
R32Egor
  • 277 posts
Posted 07 September 2021 - 09:01 AM
Oh good point did not think about Tackling the problem from that side.
Thanks for the idea
#4 GraemeC
GraemeC
  • 7,314 posts
Posted 07 September 2021 - 09:11 AM
If they are the 'standard' plastic 'Special' arches then they won't easily take an edging strip.
For a permanent solution you could swap them for some Group 2 that would take an edging strip.
If you only need a solution to get through the test then I'd remove the rivets and replace them with bolts with a couple of washers between the arch and the wing.  You may only need to do the middle ones and leave the end ones as is - just to ease the top of the arch out.  Fill the resultant gap with a bit of closed cell foam (draught excluder type stuff)
#5 mab01uk
mab01uk
  • 11,803 posts
Posted 07 September 2021 - 03:54 PM
This rubber seal strip from Minispares is used for the wheel arch to body seal for neatness such as with W&P arches and may do the job:-
http://www.minispare...MS.aspx|Back to
Edited by mab01uk, 07 September 2021 - 03:54 PM.
#6 absx2
absx2
  • 822 posts
Posted 07 September 2021 - 06:05 PM
I`ve had the P section rubber on my standard Rover arches for 20 odd years as the arches were taken off and the rivets were replaced with 4 mm Phillips headed bolts for rust proving maintenance.
The picture isn`t the best due to the car being very tightly parked but hopefully you get the idea !
Standard Rover Minilights and Yokohama 160/60-12`s
The only other thing you can possibly do check you don`t have positive camber as that will make the tyre stick out at the top, mine has half a degree negative and corners on rails.
Edited by absx2, 07 September 2021 - 06:12 PM.
#7 evansisgreat
evansisgreat
  • 1,095 posts
  • Local Club: Not yet
Posted 20 September 2021 - 11:25 AM
So sorry, to hijack, but what colour is that absx2? I'm looing to paint mine something very similar but haven't decided on a paint code.
