Hey guys I am having a constant issue with fuel leaking from where the fuel runs into the carb. It is connected with a 1/4" fuel line as suggested after a lot of reading but after not long it seems the inside diameter opens up more and no longer has a good seal. The inlet of the carb is not flared and I'm not sure if this should be or not? The hose I'm using is fuel grade but just doesn't seem to last. It's fine for a few months but I would like a longer fix than this especially dealing with fuel dripping onto a hot manifold.
On a side note in the photo is the carb vent supposed to be blocked up like that?
Any suggestions will be greatly appreciated.
Edited by kiwimike01, 10 September 2021 - 09:10 PM.
