What Carb Set Up
Posted 11 September 2021 - 06:24 PM
Posted 11 September 2021 - 06:28 PM
HIF44 would be my choice.
Posted 11 September 2021 - 07:22 PM
Posted 19 September 2021 - 03:36 AM
Posted 19 September 2021 - 05:32 AM
I had a hif44 before but wasn't a big fan.
What was it about the HIF you didn't like ?
Posted 19 September 2021 - 09:11 AM
Just had tune up of my wife's 1330. Standard MG Metro head, HIF44 (BDL needle)and minispares evo001 cam. 89bhp/93ftlbs.
Posted 19 September 2021 - 10:24 AM
Twin 1.5” or a single 1.75” SU would be good options too
At the end of the day you’ll probably get much the same power using any of the choices, so just pick whichever one you can tune and you want on your car
Personally for my Mk1 I’ve been running a Dellorto 40 on a period manifold. I’ve tried some twin HS2 and I’m working on some twin H4 carbs. I just think they look cool, there’s no reason other than that. It’s not the most practical or sensible option, but that’s not why I have a mini
Posted 19 September 2021 - 11:39 AM
Edited by Steam, 19 September 2021 - 11:40 AM.
Posted 19 September 2021 - 08:53 PM
Posted 20 September 2021 - 02:03 AM
There are some shorter 3.75” manifolds that will fit with a standard firewall and centre speedo. My car has a 90 degree speedo adapter so that you can fit a filter as well
Posted 23 September 2021 - 05:56 AM
An SU carb will never have the same snappy throttle response as a Dellorto/Weber
More information on the 3.75” manifolds and where are they available?
Posted 23 September 2021 - 07:16 AM
Loads of Weber/Dellorto manifolds on MiniSpares.
Failing that, Google.
Posted 24 September 2021 - 01:06 AM
That manifold with a 90 degree speedo adapter (from a Rover 3500) and a ramflo air filter all fit in
Maniflow also makes a short one
Posted 07 October 2021 - 10:13 AM
Posted 07 October 2021 - 10:18 AM
In the photo above I had a filter on the clutch breather. The tappet cover breather goes through a catch can then into the air filter. The ramflo filter comes with a 1/2" port
