Led Side Repeaters And Front Indicators
Posted 15 September 2021 - 11:13 AM
The LED indicators from Minispares are not too bad and still look reasonably stock. I think it’s much better than sticking an LED bulb into existing housing.
ps.: how do you embed video to the forum from imgur?
Posted 15 September 2021 - 01:22 PM
Are the indicators the Land rover type ones? For the side repeaters how much are they? Do u have a link to them
Posted 15 September 2021 - 01:42 PM
Yes, front indicators are Land Rover ones. I think side repeaters are the same as well though Minispares do sell them on their site. You do need to fit a resistor for the front indicators…Are the indicators the Land rover type ones? For the side repeaters how much are they? Do u have a link to them
Front indicators: http://minispares.co...89.aspx|Back to
Side repeaters: http://minispares.co...|Back to search
Resistors: http://minispares.co...ED.aspx|Back to
Edited by Aria Aradhea, 15 September 2021 - 01:43 PM.
Posted 16 September 2021 - 06:03 AM
Why not check out the ones here
https://spiyda.com/
My concern is that their LED chips are only facing straight on and not providing enough light spread though…
Posted 16 September 2021 - 07:10 AM
The WIPAC Land Rover LEDs are listed as "E" marked for compliance to car lighting regulations for indicators, so would expect the light spread/pattern to not be a problem.
Posted 16 September 2021 - 07:27 AM
Yeah, I was referring to the spiyda ones. That's why I went with the Minispares/Wipac LED unit ones...
Posted 05 October 2021 - 07:56 AM
The resistance on the circuit is very different, causing the indicator and hazard relay to flash very quickly, just like when the resistance is lowered when a bulb in the circuit blows.
If your fitting LED indicators, it’s better to change all the indicator bulbs at the same time and replace the relay with an LED compatible one. Saves all the resistor fitting too.
There’s quite a difference in the quality, output lumens and pattern spread in LED’s, that would be a whole new thread in itself.
