Edited by Blake71, 21 September 2021 - 10:45 AM.
Posted 21 September 2021 - 10:44 AM
Posted 21 September 2021 - 02:41 PM
I have not been able to find that part listed anywhere.
You might check to make sure it is leaking as I had one cracked like that and it did not leak wuth the pipe inserted.
I am afraid used may be the only source for a repalcement.
I have been looking at finding a brass threaded bushing to replace it.
It would require drilling to the correct size for the bushing and then using an older style threaded intake servo take off.
All the bushings I have found are tapered pipe thread with out the correct threaded ID for the servo take off.
If someone else has any ideas I am interested as well.
Edited by tmsmini, 22 September 2021 - 06:18 PM.
Posted 21 September 2021 - 08:27 PM
From a post i made back in June 2018-
'Fitted to lots of Rovers, MG Rovers, & Land Rovers.... & Minispares stock it! http://www.minispare.../LZN100220.aspx
....Wish i knew that part number years ago when i had to drill/tap the manifold & have a brass insert made up to accept a non-MG Rover hose connector.'
Minispares are out of stock but....
https://rimmerbros.c...em--i-LZN100220
https://www.mgobsess...nsert-press-in/
https://www.ukmgpart...ifold-lzn100220
Posted 21 September 2021 - 09:29 PM
Thanks guys thats great
Posted 21 September 2021 - 11:29 PM
I figured they must have been used in other cars, but could not find a part number
I am also looking to blank off the servo take off for a Microsquirt application in another car, do you know what size drill/tap you used?
"when i had to drill/tap the manifold & have a brass insert made up to accept a non-MG Rover hose connector."
