Wire Size For Electric Fuel Pump?
7 replies to this topic
#1 croc7
croc7
  • 819 posts
Posted 26 September 2021 - 06:11 AM
I’m planning to remove the mechanical fuel pump and replace it with the AUF214MS electric pump from mini spares. Probably source power from the dash mounted ignition switch through a separate toggle switch (anti-theft) then back to the subframe mounted pump. Will 16 AWG wiring do the job?
Edited by croc7, 26 September 2021 - 06:12 AM.
#2 nicklouse
  • 18,740 posts
Posted 26 September 2021 - 08:02 AM
Easy. Could drop to 1mm
#3 timmy850
timmy850
  • 3,407 posts
  • Local Club: MITG
Posted 26 September 2021 - 08:43 AM
Or alternatively chuck a relay in the boot and get power direct from the battery. Your trigger wire can come from the ignition switch
Saves all the current going all the way up the car
#4 Ethel
  • 26,137 posts
Posted 26 September 2021 - 09:56 AM
If you use a normally closed relay you could use the oil pressure switch to cut the pump as a safety feature. If you had a crash, the engine would likely stall, killing the oil pressure.
#5 croc7
croc7
  • 819 posts
Posted 27 September 2021 - 06:15 AM
Thanks for the reply. My question is; wouldn’t the trigger wire have to run the length of the car from the ignition switch to the pump?
#6 timmy850
timmy850
  • 3,407 posts
  • Local Club: MITG
Posted 27 September 2021 - 06:54 AM
Yes, but the trigger wire runs very little current, only enough to turn on the relay. The high current wire can go from the battery to the relay and then to the pump
#7 Ethel
  • 26,137 posts
Posted 27 September 2021 - 10:40 AM
It'll draw less than a brake light & there are 2 of those wired together. A relay in the boot could be an ignition source for spilt fuel - the risk's likely as negligible as the extra current draw.
#8 nicklouse
  • 18,740 posts
Posted 27 September 2021 - 11:29 AM
What high current wire? A pump will pull 3-5 amps only  the brake lights are just over 3 amps for the pair. Add side lights and you are getting up to 5 amps total.
