Another Rev Counter Problem
Best Answer Vanman20 , 30 September 2021 - 12:47 PM
We have success.
Got that test circuit working with a bulb,was showing 2,500 rpm.
There is an adjuster but it's not a screw , it's the white arm in the picture below.
Adjusted that to 3000rpm and now it not only seems to work reasonably accurately it also starts reading without me having to tap the glass
IMG-20210930-132834-1-1.jpg Go to the full post
16 replies to this topic
#1 Vanman20
Vanman20
  • 274 posts
Posted 27 September 2021 - 07:47 AM
Fitted a Smith's rev counter out of a 4 cylinder Triumph.Wired in with a 12 volt feed and it under reads by about half.
Wired in from the the voltage stabilizer and it's all over the shop.
Any guidance much appreciated
#2 nicklouse
  • 18,697 posts
Posted 27 September 2021 - 08:02 AM
what is your ignition system. are you 100% sure it is from a 4 pot engine?
#3 Vanman20
Vanman20
  • 274 posts
Posted 27 September 2021 - 09:10 AM
Std MG Metro,non electronic.
Yes definitely 4 cylinder,says on the fascia and written on the housing is Dolomite/Spitfire/Midget so it must have come from a breakers
#4 KTS
KTS
  • 2,462 posts
Posted 27 September 2021 - 10:31 AM
you sure it's non-electronic (i.e points) ?   MG metro, I think, would as standard have been fitted with the 65DM4 type distributor which used the electronic switch module
#5 Vanman20
Vanman20
  • 274 posts
Posted 27 September 2021 - 10:54 AM
It has points,59D dizzy
#6 nicklouse
  • 18,697 posts
Posted 27 September 2021 - 11:47 AM
The turbo came with Electronic but not the MG.
pics of the back of the rev counter or any ID info would help.
#7 Chris1275gt
Chris1275gt
  • 966 posts
Posted 27 September 2021 - 11:53 AM
Is it wired to dash voltage stabiliser as that is stabilised at 10 volts not 12v don’t I know if that would make it not work properly.
#8 Vanman20
Vanman20
  • 274 posts
Posted 27 September 2021 - 12:39 PM
#9 sonscar
sonscar
  • 3,047 posts
Posted 27 September 2021 - 02:44 PM
Is this one where the 12v for the coil passes through it in series before going to the coil?is 12v switched supply,,,rev counter ,,,then +ve of coil removing the current feed.Just a thought,probably incorrect,Steve..
#10 KTS
KTS
  • 2,462 posts
Posted 27 September 2021 - 02:55 PM
http://www.mgb-stuff.org.uk/tach.htm
..about halfway down the page looks like yours
#11 sonscar
sonscar
  • 3,047 posts
Posted 27 September 2021 - 03:07 PM
Looks look the above,I was thinking of the earlier version.You need 12v unregulated and connect to the negative of the coil.These are old and work poorly as a rule,Steve..
#12 Vanman20
Vanman20
  • 274 posts
Posted 27 September 2021 - 03:47 PM
It does seem like the voltage stabilizer is messing with stability lol.
But even with a 12v supply it under reads.
Maybe someone has had it apart before and put the needle on in the wrong position....or maybe I'm clutching at straws and it's knackered
#13 sonscar
sonscar
  • 3,047 posts
Posted 27 September 2021 - 05:17 PM
Isn't there a test using a battery charger that gives you 3000 rpm?Must google it,Steve..
#14 Spider
  • 15,142 posts
Posted 27 September 2021 - 06:33 PM
Those tachos need a 12 V supply. It's an RCV type of Tacho. I have found inside them there is a pot for calibrating, but if opening it up for adjustment, I'd suggest replacing all the Electrolytic Capacitors too (there's only one or 2 of them) as they'd likely be on their last legs by now.
You can calibrate the unit yourself, find yourself a 12V AC Plugpak (or transformer), connect that between Earth and the Pulse Input Terminal. In the UK, it should read 3000 RPM and in the US, 3600 RPM.
#15 Vanman20
Vanman20
  • 274 posts
Posted 28 September 2021 - 01:00 PM
Tried that but don't get any reading.....googling suggests this needs to be done with the coil or a bulb wired into the circuit
