Starter Moto Fault?
1 reply to this topic
#1 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 04 October 2021 - 07:40 AM
Its a 1992 car with corresponding age starter motor. Fails to start, checked the connections for cleanliness, no changes. When cranking, voltage drops to 8 - 10 V on a fully charged battery, even with a jump start thingy attached. Am I right in thinking the starter draws too much power for ignition (its megajolt) to fail?
Ive done carb cleaning, etc checks.
#2 Ethel
  • 26,580 posts
Posted 04 October 2021 - 09:20 AM
The voltage drop sounds normal. You could hook up a sparkplug, or timing strobe, to see if it sparks while it's been turned over.
Doing it with & without the plugs in should test your theory.
