I am currently replacing the ball joints on my 1972 mini. I am changing from drums to discs. In regards to the ball joints. I have 2 types of lock rings that the bleed nipple screws through. One has a large bent flat rectangle lip on it. Can someone enlighten me as to which ball joint this goes on. The Top or the bottom
Ball Joint Lock Tab
Ol timer
, Oct 06 2021 03:58 PM
4 replies to this topic
Posted 06 October 2021 - 03:58 PM
Posted 06 October 2021 - 04:01 PM
The one with the brake pipe holder is for drum brakes.
Posted 06 October 2021 - 04:02 PM
Thanks. I thought that. However you need both on each hub. Be it disc..so can this one go in any position ?.
Posted 06 October 2021 - 04:04 PM
Yep.
Posted 06 October 2021 - 04:06 PM
Cheers.. back to doing the hubs.
