Med Stub Stack & Filter Clearance Issues
16 replies to this topic
#1 Junaid
Junaid
  • 12 posts
Posted 26 October 2021 - 05:08 PM
Has anyone ever come across a problem like so, managed to get the stack on, but there no place for the filter, HS4 carb on standard cast iron manifold
First image is the current filter
Edited by Junaid, 26 October 2021 - 05:32 PM.
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 26 October 2021 - 06:35 PM
Thinner carb spacer https://www.theminif...tting-bulkhead/
#3 Junaid
Junaid
  • 12 posts
Posted 26 October 2021 - 07:31 PM
I removed the spacer and it doesn't help
#4 Maccmike8
Maccmike8
  • 1,101 posts
Posted 26 October 2021 - 07:53 PM
Change of stabilisers?
#5 nicklouse
  • 18,667 posts
Posted 26 October 2021 - 07:58 PM
What engine in what year car?
#6 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 26 October 2021 - 08:02 PM
Cast iron manifold isn’t doing you any favours.
#7 Junaid
Junaid
  • 12 posts
Posted 26 October 2021 - 08:06 PM
Was thinking of using an adjustable engine steady arm
1983 1275, South African mini
Does anyone know if the alloy intake has a different angle and if it positions the the carb higher
#8 nicklouse
  • 18,667 posts
Posted 26 October 2021 - 08:12 PM
So it has always been a 1275? If so, and I don’t know about the SA subframe changes, then I don’t think the UK 1275 engine steady will help. So an adjustable one could help. Never measured the differences on the inlets.
TBF that filter assy on that set up will bring you nothing.
#9 Junaid
Junaid
  • 12 posts
Posted 26 October 2021 - 08:47 PM
Yes always been a 1275
And yes you're right, probably wouldn't do much performance wise, but wanted the induction noise
#10 nicklouse
  • 18,667 posts
Posted 26 October 2021 - 08:58 PM
WI’ll not help noise. For that you need to refit the original filter housing with the elbow bolted into the carb. That helps deflect the noise and also recuses the standing wave pattern in the induction port.
the standard housing with a KN filter element (and some add holes in the casing) is better than any of the pancake or cone filters. The MED set up won’t be bad but will do nothing for the noise.
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 27 October 2021 - 06:00 AM
Nick, read it again - he WANTS the noise.
#12 croc7
croc7
  • 815 posts
Posted 28 October 2021 - 10:23 PM
Agreed. I have that air cleaner on my HIF44 but have the Mini Spares alloy intake and LCB exhaust. Its a tight fit but it works. Also elected to use a 90 degree adapter for the speedo cable.
Edit; I always forget to mention that I use the 90 degree speedo adapter on the center mounted speedo used on the MKI/MKII minis. Never used them on the ones mounted in front the driver.
Edited by croc7, 01 November 2021 - 03:35 AM.
#13 Mini Manannán
Mini Manannán
  • 2,859 posts
  • Local Club: man Estate
Posted 29 October 2021 - 07:33 AM
How good are your engine mounts?
#14 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 29 October 2021 - 11:13 AM
Need an angled spacer to tilt the carb up for some cleance.
The privious owner of my car had cut the speedo opening a tad to get a filter / old alloy inlet to fit.
With a minispare inlet and and a HIF44 and  filter there is space as the inlet brings the carb up a bit.
Edited by no66, 29 October 2021 - 11:13 AM.
#15 jeffster06
jeffster06
  • 113 posts
Posted 29 October 2021 - 12:21 PM
I had to go to a 90 degree adapter as well after my cable snapped about 50 miles later. I don't think you would need one if you have the speedo behind the steering wheel though, if I remember correctly it goes through the bulkhead in a different location. The filter is definitely a tight fit though.
Edited by jeffster06, 29 October 2021 - 12:22 PM.
