I'm pretty sure my float valve doesn't close properly because there is fuel leaking out of the top onto the lid of the float chamber. It's not an adjustable float so I was wondering if I can use any type of washer to space the needle lower so it closes sooner? Or any other suggestions? It seems like a lot to buy a washer off a mini parts website and get just that sent to me.
Float Valve Washer Hs4
kiwimike01
, Nov 09 2021 04:40 AM
4 replies to this topic
Posted 09 November 2021 - 04:40 AM
Posted 13 November 2021 - 04:58 PM
Is this a new valve?
Ac
Ac
Posted 18 November 2021 - 08:00 AM
Yes new valve. It's the superflow type. I also just put on a n adjustable float. At factory height the gap is nearly 3 times the 1/8 inch recommendation
Posted 18 November 2021 - 08:01 AM
Fit a stock valve you will get the stock setting.
Ac
Ac
Posted 18 November 2021 - 09:12 PM
I tried Supaflows, could not get it to seal. Put standard needles in, no problem.
