Are either any of these dizzies any goof for a standard A+ 998? Quality and reliability?
https://www.ebay.co....UoAAOSwtM1frqWw
https://www.ebay.co....AMAAOSw9-JfrqUo
Posted 10 November 2021 - 12:10 PM
Posted 10 November 2021 - 03:54 PM
Not sure about those units, but I know the 123 electronic units sold by Minispares are rated well but they come at a price
http://minispares.co.../C-27H7773.aspx
Posted 10 November 2021 - 04:41 PM
It’s just I’m trying to work out if its better just buying a brand new one, which may or may not be any good and of dubious quality.
Or finding a used original local 59d dizzy that isn’t knackered (trying to with ignored messages or just told ‘to buy new’) and converting it to electronic, so also having the option of switching back to points at the roadside if needed.
It’s only a bog standard 998 with standard air filter/box, cast-iron manifold, pea shooter exhaust. As my current electronic dizzy is wrong for the engine and has other issues.
Posted 10 November 2021 - 05:22 PM
Posted 10 November 2021 - 05:31 PM
I’ve already have a 64md electronic dizzy, but for some reason with the vacuum advance connected I’m getting full max advance between from idle to 2k. And I think also causing a vacuum leak through the vacuum advance unit/dizzy.
Running it with the vacuum advance blocked off has helped, but it’s still not running right.
Posted 10 November 2021 - 06:54 PM
Posted 10 November 2021 - 07:22 PM
I used the Powerspark dizzy when i converted Paddy's 998 A series engine. Went in, started up straight away and after a minor tweak ran spot on. No recurving required.
Posted 10 November 2021 - 07:32 PM
I've just edited the title to better reflect the subject.
Posted 10 November 2021 - 08:02 PM
Which is more the answer/reply I was looking for.
Or, it didn’t/had to be modified to fit, the advance curve was way off for it to run or failed etc.
Pricing up its works out about the same to buy a used/unknown (of course the sellers going to claim it’s ok) dizzy than it does for to buy a new one, and then the same on top for the electric conversion.
As the only spare dizzies I have are one for an a plus that won’t fit, and a ducellier that was originally on the car. (and won’t be refitted anytime soon)
Posted 10 November 2021 - 08:37 PM
There is also Accuspark, which is very very similar.
http://accuspark.co....alPage.htm#Mini
you can buy the bits individually as well.
Posted 11 November 2021 - 07:20 AM
Posted 11 November 2021 - 12:00 PM
Stick with the 65dm4 but ask either AC Dodd to sort it or use H&H Ignition to check it over and recurve it.
Posted 11 November 2021 - 02:41 PM
I had a Powerspark fitted to my Minor for a while and it was good. I swapped it over to my Commer camper after a couple of years (Minor under resto) and it lasted another couple of years until the module failed. I've had a few of the modules fail on me, the one that lasted the longest was the original Simonbbc one and that was in for just under ten years. When the Minor is finished I'll be looking at the Distributor Doctors range and will probably go back to points on that car.
Posted 12 November 2021 - 09:58 AM
i see a lot of positive talking about AC Dodd, but how can you connect with him?
Posted 12 November 2021 - 10:01 AM
You can message him on this forum
