Intermittent Indicator Issues(And Lights)
6 replies to this topic
#1 bae1994
bae1994
  • 166 posts
Posted 14 November 2021 - 04:55 PM
So my indicators seem to intermittently keep stop working and then will then start working again.
I've replaced the flasher relay and even when they're not working there is still 12v constant at the relay.
I also lost all my lights the other day while driving so had to pull my flash of high beams on which worked.
Could the stalk be the culprit? Or is there some other likely places to check? (I got rid of the bullet connectors behind the grill years ago so it won't be them)
It's a 1994 sprite if that's any help.
#2 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 14 November 2021 - 05:00 PM
Check for loose connections at the top fuse (4 fuse box) also check earth's and then the stalk last
#3 bae1994
bae1994
  • 166 posts
Posted 14 November 2021 - 05:11 PM
Ideal, will do this tomorrow weather permitting.
#4 RealSlow
RealSlow
  • 24 posts
Posted 15 November 2021 - 08:07 PM
The whole fuse box itself can start to fail as well. I was getting intermittent failure of my wiper/tach/heater, and when I pulled the fuse box, there was a bunch of corrosion on some of the connectors on the back.
#5 beardylondon
beardylondon
  • 1,612 posts
Posted 16 November 2021 - 06:40 AM
+1, my lights and indicators were doing strange things, I unscrewed the fusebox from the bulkhead and found the whole fusebox was corroded, so I replaced it and it’s been fine.
#6 bae1994
bae1994
  • 166 posts
Posted 18 November 2021 - 09:21 PM
Hmm so I whipped the fuse box off the bulkhead and it is pretty corroded up on the back! So I've ordered one from minispares and will give that a go thank you.
Hopefully it fixes it but I figured if not it can't hurt
Edited by bae1994, 19 November 2021 - 11:51 PM.
#7 bae1994
bae1994
  • 166 posts
Posted 25 November 2021 - 10:25 AM
So update on this, I swapped the fuse box and it seems like that has solved the indicator issue.
So thank you for the help.
And the light issue I believe is the aftermarket toggle switch is on its way out so will swap that for a new one.
