Fuel And Temp Guage's Are Not Working
10 replies to this topic
#1 nbw
nbw
  • 16 posts
Posted 29 November 2021 - 01:46 PM
1996 Mini Tahiti
Hi all
I have an issue with both the Temp and Fuel gauge's not working
I have cleaned both the connectors on the fuel tank and the temp sensor.  But i am still not getting any feed back in the gauges.
For both not to work makes me wonder if there is something i am missing.
Anyone able to point me in the direction to look at?
Photo of the dash below.
Can i ground the black and green cable going to the fuel sender to see if it goes to full?
The car has sat for a long time, with no fuel in.  Not sure if that helps identify where the issue is
#2 Spider
  • 15,863 posts
Posted 29 November 2021 - 06:52 PM
I'd say the Voltage Stabaliser is karput.
#3 nbw
nbw
  • 16 posts
Posted 29 November 2021 - 08:42 PM
Hi
Thanks for the reply.
I have opened the dash up and tried to find the voltage stabilizer but I cannot. I am assuming it's built into the dash cluster dials and not easily accessible?
Nick
#4 mini-mad-mark
mini-mad-mark
  • 925 posts
  • Local Club: northants wot no brakes
Posted 29 November 2021 - 10:33 PM
Hopefully I recall this correctly - pretty sure it was on here - the older smiths gauges had a separate VR  plugged into the circuit board but the later ones (NipponSeiki - ?) have VR built into the dial I believe - not sure what the fix is for the later ones though sorry
I bet someone else will respond with a bit more help...
#5 Spider
  • 15,863 posts
Posted 29 November 2021 - 11:54 PM
Thanks for bailing me out !
I know they have a Regulator, but I am not sure where they are, it makes sense though that it would be inside the assembly somewhere !
There's a fix here;-
https://www.theminif...tage-regulator/
#6 nbw
nbw
  • 16 posts
Posted 30 November 2021 - 08:04 PM
Thanks both.  Looks like the fix i needed!  Parts ordered!
#7 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 30 November 2021 - 10:18 PM
That's the correct fix that Spider linked, some of the part numbers may now be superceded but a decent parts Advisor should still cross reference
#8 nbw
nbw
  • 16 posts
Posted 07 December 2021 - 09:21 PM
I am having a stinker with the guide chaps
I have been able to remove the temp voltage unit from the cluster
but i am unable to undo the brass nut to break the contact as part of the guide linked in the post above.  Correct me if i am wrong, but i am to break the current at the bolt
Attached File  PXL_20211207_204303576.jpg   29.69K   0 downloads
Attached File  PXL_20211207_204331723.jpg   28.21K   0 downloads
Attached File  PXL_20211207_204308958.jpg   29.56K   0 downloads
The image in the guide:
Attached File  f4d8feddb072a690a35cbe802f656f4f3e0a7fae.jpg   34.8K   0 downloads
Its becoming a tad frustrating as i cannot apply too much pressure as i feel i will damage the unit.
Any suggestions?
Nick
Edited by nbw, 07 December 2021 - 09:24 PM.
#9 Tornado99
Tornado99
  • 750 posts
Posted 08 December 2021 - 12:13 AM
From the guide it seems to states to block the contact at thr brass nut/bolt and he used electrical tape (black blob wrapped around the brass in one image). So nothing about undoing the nut, just "breaking" the electrical contact. I'd use something better than e tape, as that tends to age poorly. A bit of heat shrink would be better i'd think.
#10 sonscar
sonscar
  • 3,255 posts
Posted 08 December 2021 - 08:24 AM
The nut will be welded to the brass arm so that the screw can be used to adjust it.Try removing the screw and sleeving the contact?Steve..
#11 Spider
  • 15,863 posts
Posted 08 December 2021 - 09:45 AM
That's a vibrating contact.
Just gently push them apart a little and slip some tape between them, than let them go to hold the tape captive.
