Stuttering Under Load
Posted 06 December 2021 - 08:49 AM
If I plant my foot it stuttering like lack of fuel then comes good. It makes no difference putting on the choke.
I have checked the dash pot oil and replaced it with 20w50 as I was out of SU oil. I also replaced the carb spring to a red spring as the car has a stage one kit. It made no difference.
I have replaced the plugs with new ones even though the old ones looked fine.. air fuel mix looks good on the new sparks. Tuned it with a gunson spark colourplug to get blue . But the issue is still there.
Any other ideas to look for ?
I am lost now to know what else to look for
Posted 06 December 2021 - 10:12 AM
My first suspect for stuttering under load would be high tension: HT leads, distributor and plug caps.
Voltage requirement by the spark plugs rises with load and may cause tracking issues.
Will it run through the rev range, cleanly, on light throttle application?
Posted 06 December 2021 - 11:31 AM
Posted 06 December 2021 - 11:32 AM
Posted 06 December 2021 - 11:59 AM
Running it up in neutral will not test the HT system.
Inspect, dry and spray cap and leads with 'Damp Start', or similar.
Consider replacing cap, rotor and leads, if they look damaged.
Posted 06 December 2021 - 12:44 PM
Thanks for your help, will give it a look tonight , pending weather.
I do have new leads in the shed somewhere and will start with those
The Dist is rather old and crusty.. it did come with the mini and I did replace points to electronic about 2 years ago.. at that time the advance plate (if that is what its called) inside the Dist was a bit crusty and seized.. I did free that up and it has worked since then, maybe that was a good indication as to the condition of the Dizzie
Posted 06 December 2021 - 04:31 PM
The coil is also a possible culprit, make sure the area around the HT ouput is clean, but I suggest checking/changing the service items first.
Posted 06 December 2021 - 06:57 PM
Edited by Ol timer, 06 December 2021 - 07:11 PM.
Posted 06 December 2021 - 07:46 PM
Thanks again. Will do the leads soon as I have the chance. I am considering replacing the dizzi as well due to the original issues I had with it in the beginning. I believe it is a 45D. What electronic one would you recommend?
That's outwith my area of expertise.
Any others with recommendations?
Posted 07 December 2021 - 05:03 PM
id stick with standard dizzy as advance curve will be correct just change points and condensor for electronic unit that fits inside cap. then if fails can put old parts in a get you home. also check bob weights in dizzy body are free and springs not snapped. always used AAV in my 998 with stage one no probs.
Posted 07 December 2021 - 06:41 PM
Posted 26 February 2023 - 07:11 PM
