Smart Carb On A Mini?
9 replies to this topic
#1 Tornado99
Tornado99
  • 750 posts
Posted 07 December 2021 - 07:20 PM
Just came across this carb design today....
Originally developed for small dirt bike 2-stroke applications but has been fitted to 1000 c.c. Ducatti race bikes.
Flat side throttle slide, semicircular cross section "needle", auto-compensation for air pressure via float bowl air pressure equalization.
Wonder if it could be adapted for a mini?
https://smartcarbfuelsystems.com/
#2 nicklouse
  • 18,758 posts
Posted 07 December 2021 - 08:01 PM
Sounds like someone is just trying to copy the SU. Or never seen an SU.
#3 Maccmike8
Maccmike8
  • 1,101 posts
Posted 07 December 2021 - 08:30 PM
Quite interesting that.
#4 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 07 December 2021 - 08:50 PM
I was thinking along the same lines, it does seem very much like a modern attempt at an SU carb
#5 Tornado99
Tornado99
  • 750 posts
Posted 07 December 2021 - 09:04 PM
Well it does have some similarities....as no extra jets or "power" pump. But the internal float pressurization feature and semi-circular needle are not SU derived, correct? Plus its flat side configuration...which seems to be a holy grail thing on classic bike forums I frequent. Not sure what happens when choke for cold starting is needed?
#6 sonscar
sonscar
  • 3,084 posts
Posted 07 December 2021 - 09:17 PM
Auto float pressure bla bla bla,does this mean it has a vented float bowl?Race anything is not always desirable on a road car.They are very shiney though and I expect the plastic parts will love being close to the exhaust.Just my jaundiced view.Steve..
#7 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 08 December 2021 - 03:25 PM
$700!  Yeowch!
#8 PoolGuy
PoolGuy
  • 867 posts
Posted 08 December 2021 - 06:59 PM
Is it just me that switches off when I read, "resulting in increased power (10% More HP) using less fuel (30% Improved Fuel Economy)"?
#9 Shooter63
Shooter63
  • 1,110 posts
Posted 08 December 2021 - 07:35 PM
I had the misfortune of coming across a lectron back in the mid 80s when I was part of a race team, at the time it was hailed as the next great thing, try as we might we couldn't get the engine to run cleanly so we went back to a mikuni, in fact we had more luck with a Wal Phillips fuel injector which was little more than a semi controlled drip feed, great top end power but a total git in a race situation. From a personal point of view I would avoid it like the plague
Shooter
#10 mk1leg
mk1leg
  • 9,343 posts
Posted 08 December 2021 - 10:31 PM
there are several race bike carbs, Mikuni RS Series, Keihin CR Racing, all fit most 7port heads or single use
