Headlight Cable
Best Answer KTS , 12 December 2021 - 05:22 PM
as long as the existing wiring is serviceable, it should be adequate
a relatively straightforward improvement to the headlight wiring, that doesn't require completely rewiring the whole circuit, is to use the existing main and dipped beam feeds (blue/white and blue/red respectively) as triggers to relays that provide the power direct to the headlights from the main battery feed
you can buy pre-built harnesses to allow you to do this with relative ease - Wired by Wilson is one supplier
Go to the full post
8 replies to this topic
#1 Geofff
Geofff
  • 22 posts
Posted 12 December 2021 - 03:53 PM
I'm planning to fit new headlights into our 93 Sprite but I am getting hung up by cable sizing.
I have read all the posts by KernowCooper but I'm still unsure.
As far as I can tell the original headlights were 45/40 watts. I plan to fit 60/55 watt H4.
The blue/white cable to the main beam measures 2.5mm over the insulation.
KernowCooper rates the Amp draw on the new lights at just under 10 amps.
The question is should I rewire the headlights back to source with new cable as 2.0mm2 is recommended for headlights..or 1.0mm2..or will the wiring already in the car be sufficient amp rating?
I much prefer nuts and bolts to volts and amps.
thanks
#2 KTS
KTS
  • 2,472 posts
Posted 12 December 2021 - 05:22 PM   Best Answer
#3 Geofff
Geofff
  • 22 posts
Posted 13 December 2021 - 02:49 PM
Now that is very useful. Many thanks for the reply.
I like the idea of going via a relay. I will contact Wired by Wilson.
Again many thanks
#4 andyapanel
andyapanel
  • 627 posts
Posted 13 December 2021 - 03:55 PM
I second that recommendation for Wired By Wilson. Top notch work.
#5 cal844
cal844
  • 9,663 posts
  • Local Club: TFMOC
Posted 13 December 2021 - 05:46 PM
Third here for Wired by Wilson, I've had a radio head unit power lead fitted for 8 years, been faultless
#6 smurfomatic
smurfomatic
  • 461 posts
Posted 13 December 2021 - 05:52 PM
Wired by Wilson is great, produced a modified loom for me and was a great help throughout the process.
#7 Spider
  • 15,206 posts
Posted 13 December 2021 - 06:21 PM
You'll find it very worthwhile replacing the wiring with something a little bigger than what they factory provide and adding relays.
The problem with the factory stuff is while it can - just - handle the load OK, there's a lot of losses along the way because it's smaller wire (put in more technical terms, the smaller wire has a higher resistance) and to further compound this, the total length of wire, from the solenoid (where it picks up the power from), through to the Headlight Switch and then up the column to the Dipper Switch, before heading out to the Headlights is quite a few metres of cable, adding more losses (resistance) along the way. These losses cause there for to be less voltage to the lamp. just a drop of 5% in voltage reduces the lamp brightness by more than 15% and a 10% drop in voltage reduces light output by 33% - 1/3 !  It's easy to see how much you loose by switching on the headlights, measuring the voltage at the starter solenoid and then again at the headlight terminals - I think you'd be surprised.
Fitting the next size up cable and relays in the engine bay, you'd be surprised how much brighter the standard headlights would be, but all the same, I wouldn't discourage you from upgrading to H4s.
#8 IronmanG
IronmanG
  • 1,269 posts
  • Local Club: Box hill. Lsmoc member
Posted 13 December 2021 - 07:01 PM
Another positive vote for David at W by W
#9 Geofff
Geofff
  • 22 posts
Posted 14 December 2021 - 04:06 PM
Thank you for all the comments.
I'm going for the larger cable and a relay by W W. Wired by Wilson have solved another consideration and that is wiring in 2 spot lights.
Spot lights are a must have.
I have noticed that W by W do a harness that incorporates both headlights and spot lights.
Issue solved so very many thanks to you all.
